Go Back   ZR-1 Net Registry Forums > Club Regional Areas > Mid-Atlantic Region
Old 06-07-2010   #1
Aurora40
Aurora40's Avatar
Default Ok, why Bendpak?
So it seems like the WAZOO is sponsored by Bendpak! I've been looking into lifts, and am just wondering, why theirs? Not to suggest there is anything wrong, but what were the main deciders for you guys?
I was a little surprised to find they are manufactured in China. What is the selling point over something like a Backyard Buddy that is made here?
As an aside, I think my 9' ceiling is going to be a bit of a limiter. Assuming 8-12" for the garage door once I move it up, that means I can move a 48" 'vette about another 48-52" off the ground. That sorta sucks...
Old 06-07-2010   #2
ZR1Vette
ZR1Vette's Avatar
Default Re: Ok, why Bendpak?
Not downing BendPak... but I decided on DirectLift Pro8 mainly because of (four post) column height due to garage door clearance. As long as the lift has the newer cert stickers then I see no problem
Old 06-07-2010   #3
Scrrem
Scrrem's Avatar
Bob,
I'm in the same boat with my ceiling but I figured its a whole lot better that laying on my back like I did pulling my rear axle.
On the lift, I was going to get the same lift the Direct Lift like Michael has but what swayed me was the pneumatic operated safety's. I just didn't like that long bar that goes the length of the lift releasing the safety's. Seemed like you could have a problem if you hit it by mistake and bend something and get the linkage out of wack. Does it justify the cost...probably not...personal perferance I guess.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 06-08-2010   #4
QB93Z
QB93Z's Avatar
Bob,
I chose the BendPak because of: High quality construction, pneumatically operated safety latches, safety "stops" are independent (sort of) from the support column, and the ability to add a rolling hydraulic jack.
The safety stops issue was most important to me. The BendPak's safety pawls are each independently engaged by spring action unless they are pulled out by a air piston. So it is very, very unlikely that even one safety would fail to engage on uncontrolled downward motion. On the lifts that have a lever system to hold the safety pawls disengaged, it appeared to me that a single failure (for example binding in the main lever) would keep ALL the pawls from engaging.
In some lifts, the safety pawls engage with a catch tab welded to the support column. It seemed to me that if the column got twisted (for some very unlikey reason), the engagement of the safety pawl could be compromised. In the BendPack the safety pawls engage with a very heavy duty steel plate with openings (a ladder) that is internal to the support columns, but not welded to the column.
By the way, I just buried a good friend who was working on his car on a jack. The jack apparently slipped out and he was crushed. My recommendation is buy a good lift!!!
Old 06-08-2010   #5
Aurora40
Aurora40's Avatar
Damn Jim, that is terrible! Sorry to hear about your friend.
The backyard buddy seems to have a pretty solid locking mechanism, plus a backup lock if the cables go loose. It also has a hydraulic pressure release limiter in case the line gets cut or something.
http://www.backyard-buddy.com/auto-lift-comparison.html
Thanks guys for the feedback, I don't have much experience with these things, so it's good to hear what went into your decisions.
Rich, how high is your ceiling? How high will you be able to lift your car?
Old 06-08-2010   #6
Scrrem
Scrrem's Avatar
I only have a 9' ceiling, so the car will only be abel to get roughly 5 feet off the ground but like I said, it's better that laying on your back.
Ron Davis Radiator
