Old 06-02-2010   #1
Eric870
Eric870's Avatar
Default Porting a stock LT5
Need info on Porting. Lots of Info (Links).
So what is the best set-up for a Stock engine?
Is there any advantage to porting the Heads on a Stock engine?
How big should the porting be? 35MM/34MM
Tools, what are the best tools for this job? Die grinder bit sizes ect..?
Eric870 is offline   Reply With Quote
Old 06-02-2010   #2
A1990
A1990's Avatar
Default Re: Porting a stock LT5
36mm and yes port the heads.
Dennis Fierstein
90 ZR-1 #2562 Atomic-Z
ZR-1 Net Registry Chairman of the Board
ZR-1 Net Registry Treasurer
A1990 is offline   Reply With Quote
Old 06-02-2010   #3
Eric870
Eric870's Avatar
Dennis, You have a 368. How much air is enough for a stock 350?
Old 06-02-2010   #4
1989ZR1#74
And paint them Atomic Orange right?
1989ZR1#74 is offline   Reply With Quote
Old 06-02-2010   #5
Porting heads is a tricky piece, I have seen a few heads sent to the gods of speed due to misalligned porting....and ZR-1 heads are not easy to find and not easy to fix. Watch out for water jackets.
Old 06-02-2010   #6
Eric870
Eric870's Avatar
Porting heads is a tricky piece, I have seem a few heads sent to the gods of speed due to misalligned porting....and ZR-1 heads are not easy to find and not easy to fix. Watch out for water jackets.
I do not want to F..up the heads. Risk vs. reward. Is it worth it? I do not want to mess with the engine it seems to me to be a low mile motor. I'm thinking maximize with bolt on?s and top end porting. But I have no fear it is a spare motor
Old 06-02-2010   #7
I am a big do it yourself person, but if you do not know the weak points of the head, you need to stay smaller on ports, going 35/36 is a recipe for disaster......you can damage the area under the lifter or go through a water jacket, there are some very thin spots, and even people with experience have trashed sets.
Pete is not cheap but I know he is an expert at it. I have done a lot of intakes but I would not wander down a head port without a guide to help.
Be careful.....
Old 06-02-2010   #8
Eric870
Eric870's Avatar
Pete is not cheap but I know he is an expert at it. I have done a lot of intakes but I would not wonder down a head port without a guide to help.
Be careful.....
Lee, that very good advice and based on your advise I?m planning on staying away from the heads. One of the reasons I bought the engine is so I could "do it myself" and learn.
Old 06-02-2010   #9
Port matching the head is ok, if you go 35-36 on the intake, port match the heads so that the transition is good, but then only go into the head with a taper about an 1" or 2" into the head, also, the port match will not be a circle pattern, it will be a cresent....if you have questions, more than happy to talk, or reach out to the pros.....Pete, Ryan, etc.
No need to port the 2ndry in the head on a port match.
Old 06-02-2010   #10
A1990
A1990's Avatar
Naw, that's my thing...Pete won't work on them if you paint them AO
Dennis Fierstein
