Old 05-31-2010   #1
Ccmano
Default Flywheel check?
I have a used (30k mile original) flywheel sitting in the garage. Does anyone know how to check and see if it is OK? Not sure if I'm keeping it or selling it, but want to be sure it's good.
H
Old 05-31-2010   #2
Hammer
Hammer's Avatar
Talking Re: Flywheel check?
Hans,
Don't know the procedure, but I know it is in the FSM.
Old 06-01-2010   #3
Ccmano
Default Re: Flywheel check?
The FSM doesn't say much, just "check for excessive looseness" by moving the plates by hand. Seems to me I read somewhere there is a tolerance for how much movement there should be. X number of inches. Although, it looks like this one is OK. It only moves an inch or less and not real easily.
H
Old 06-01-2010   #4
Install in car, rev to 7000K RPM and hold for 20 secs, repeat with clutch dump......exit vehicle, if you are as tall when you exit as you were when you entered the vehicle the flywheel is good. Sudden loss of blood is also an indicator of a bad DM flywheel.
Old 06-01-2010   #5
Hammer
Hammer's Avatar
H
Hans,
Below excerpt is from the 1991 FSM, Page 7C-12. I am assuming your 90 manual should be the same. Distance should not be more than 1.378 inches. Hope this gives you more to go on.
FLYWHEEL LASH MEASUREMENT
Figure 12
Remove or Disconnect
1. Clutch cover assembly and clutch disc, refer to clutch cover assembly and clutch disc in this section.
Important
? It is normal to rotate the primary flywheel against the secondary flywheel for a limited
distance by hand.
? This is called looseness of the dual mass flywheel.
? This looseness does not impair the function of the flywheel unless it exceeds the specifications listed below under "Measure" which may indicate internal damage.
? Dual mass flywheel will produce a clacking noise if engine has rough idle. Before replacing flywheel for noise complaint, engine should be checked for misfiring or rough operation at idle.
Measure
? For excessive looseness of dual mass flywheel.
2. Install 2 bolts which were used to retain the pressure plate to flywheel across from each other in the secondary flywheel.
3. By hand using the bolts to help rotate the secondary flywheel against the primary flywheel
clockwise until all looseness is removed.
4. Release the flywheel and draw a mark on the secondary and primary flywheels.
5. Repeat Steps 3 and 4 only rotate the secondary flywheel counterclockwise.
6. Measure the distance between the two marks, if the measurement exceeds 35 mm (1.378 in.). Replace the flywheel assembly.
Old 06-01-2010   #6
Hammer
Hammer's Avatar
One more note. When talking with marc about the flywheel in #458, he said they wear concave and the center to outside tolerance was .015" max.
Old 06-01-2010   #7
http://www.klann-online.de/Englisch/...7e090536oP.pdf
Not a Z but
Good: http://www.youtube.com/watch?v=kIg3S_n5F4E&NR=1
Bad: http://www.youtube.com/watch?v=bFnLMQNKKH8&NR=1
Old 06-02-2010   #8
Ccmano
Originally Posted by Hammer View Post
Hans,
Figure 12
Important
distance by hand.
Measure
Now that's interesting, my 90' FSM says none of that, in the very same section. It's must have been added in 91'. Thanks a bunch.
Lee, the videos a perfect, looks like the flywheel I have on the bench is perfect.
H
