05-29-2010 | #1 |
Any Tuners that can comment on these tricks?
1)Note from why new 400hp Ford motor doesn't need direct injection:
As a Coyote team engineer put it, "On a naturally-aspirated engine, the biggest benefit of DI is charge cooling-and it's a volumetric efficiency benefit and not a tolerance benefit. We squirt the injectors while the [intake] valve is open, and it's open a long time, which we haven't done before. It seems simple and gets you half the benefit of DI-for no costs at all." The only apparent downside is cylinder-wall washing at low engine speeds, so the injector is limited to closed-valve periods at low rpm. Also, the camshafts change valve timing, so that's something else to synchronize with the injector in the engine management calibration. 2)Change the firing order? the old 4/7 swap? I think you might need revised cams for the second?
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 05-29-2010 at 12:36 AM. |
05-29-2010 | #2 |
Re: Any Tuners that can comment on these tricks?
4/7 or something else, not big power in it, but can be a little. Yes. change in cam profile would be in order.
There are no limit's mans ingenuity, just as mans ingenuity will never conquer the forces & behavior of this planet...Smokey Y. |
