A pin-out of a 1990 zr-1 engine wiring harness?
TIA |
The factory servive manual ( I think the 90 was a supplement) has all the wiring diagrams and pin outs.
I have a 94 FSM, otherwise I would scan some of the pages for you. |
I appreciate it. I have the suplement, but not the wiring supplement (if that is where it is at).
I guess Ill just get out the old multi meter and start tracking it all down. ![]() |
![]() Join Date: Dec 2004
![]() ![]() ![]() However, if you would like I can go to the local office depot and I'm sure they can make copies of the pages you need and I'll mail them to you...any help? ![]() Tom
![]() Join Date: Feb 2006
The pinouts should be in the FSM.
Thanks guys. I just need the ecm pin-outs (computer plugs), and which pin is what
I am needing , cam angle sensor, injectors, ign, ait, tps, etc |
Pin-outs are only part of the story - you need signal levels and impedances too which will require more study. Holler here for help ...
#9 | |
There really arent that many sensors, so if I cannot get the pin out I will just track through continuity. I appreciate the concern though, and the offer for help ![]() Last edited by todesengel; 05-26-2010 at 01:49 PM. |
#10 |
