the spark plug o rings on the passenger side cam covers have started leaking. is there something that might have caused this, a vibration?or something else . i have owned the 92 for 3 years and have never taken them off . thanx to rick for guiding me on its removal. also is there anything to ck while its off ????
![]() Join Date: Jan 2004
Did you check the bolts for tightness? I have run across a few that have some how backed out on their own.
Robert ZR-1 Net Registry Oregon State Director 91 ZR-1 #431 Black/Black LPE 368 |
no i havenbt . i had to get an inch pound tq wrench ,which i did today. i have new o rings and got some 518 locktight so i figured i would pull it off and put new o rings on the spark plug tubes . is there anything i should take a look at while i have it off ???
![]() Join Date: Dec 2004
Brad, two things you may want to look at while you're under there.
The chain guide strips in the cam cover, and there is a breather filter where the aluminum tube comes from that maybe falling apart. ![]() Tom
tom thankyou for the heads up on the timing chain wear strips. . will be kina fun ckin out what it looks like in person under there as i have never seen that first hand
#6 | |
![]() I would be interested in hearing your thoughts after you get your eyes on this stuff. ![]()
