Old 05-19-2010   #1
hihok9
Default clutch disc pic please
Installing my clutch disc with hydraulic throwout bearing and had no old one to go by..... Assembly manual is not clear and RAM directions are poor..... anybody got a pic of which side goes toward engine. Don't want to make that mistake. Thanks!
hihok9 is offline   Reply With Quote
Old 05-19-2010   #2
Wide_One
Default Re: clutch disc pic please
Are you replacing the slave cylinder with the ram kit?
Wide_One is offline   Reply With Quote
Old 05-19-2010   #3
rhipsher
rhipsher's Avatar
Here you go.
Old 05-19-2010   #4
I think he wanted photos of the disc.
Old 05-19-2010   #5
rhipsher
rhipsher's Avatar
oops. that's easy enough without a photo. most disks have a sticker that says flywheel side. Look at your disk where the 26 tooth spline is. One side is flush with the face and the other protrudes about an inch. the protruding side faces your flywheel/engine.
Old 05-19-2010   #6
hihok9
Thanks! That's what I was looking for. There is a small collar on the side I put toward the engine.... maybe a half inch... and the side toward the tranny was a couple flat plates maybe 1/4 in wide six inches across, wide and smooth, not like the collar on the other side. The slave is the throwout, uses the stock firewall master. I had to cut the boss off the bellhousing for the slave to make clearance in my application. The hydraulic system came with aluminum flywheel as well. That's when I found out all about having to get shorter bolts ..... Learning as I go.
