Old 05-17-2010   #1
secondchance
Default Door lock and security alarm
When I had the car painted recently, I had the shop switch door lock cylinder betrween the driver side and passenger side since I had been using only the driver side to unlock. I stopped using PKE fob because I hate bulging pocket.
Since the switch, when I unlock the door it triggers the alarm. I have to insert the key, turn counter clock wise (turns off the alarm) and then turn the key clock wise and re-unlock. I use the power lock button to arm and lock doors.
I pulled the door panel yesterday to figure out what is going on but can't.
Has anyone had a similar situation? Bad switch connected to the door lock cylinder? I could not find an appropriate section in the factory manual.
Any help would be appreciated.
Old 05-17-2010   #2
todesengel
Default Re: Door lock and security alarm
I had that happen to me once on another car, and it turned out that the wire connections on the lock themselves were not properly attached (loose connection)
todesengel is offline   Reply With Quote
Old 05-17-2010   #3
secondchance
Hmmm...
Sounds like a pain in the a$$ work - tiny space, no room to stick my hand in, etc...
Any tips? Do I need to pull the lock cylinder and disassemble? I saw a sort of white plastic thing on the cylinder w/ 2 wires coming out of it. I presume this is what you are talking about?
Old 05-17-2010   #4
QB93Z
QB93Z's Avatar
I have the same problem on my 1994 ZR-1. The alarm sounds if I open the door with the key from the drivers side, but not from the passenger side. I plan to look at the door lock switch.
Come on up and we can do two at once troubleshooting.
1990 Black ZR-1 - sold
1993 Quasar Blue ZR-1
1994 Competition Yellow ZR-1
1995 Dark Purple ZR-1
Maryland State Coordinator
Old 05-17-2010   #5
secondchance
Say a week from this Saturady? 29th?
I need to change out sway bar bushings. I was at Advanced Auto Parts and they loan out the tool I need for this job. Do you have any suspension work pending?
I take it you are back from BG?
Old 05-19-2010   #6
z proud
z proud's Avatar
A trick is to drop the door latch to get to the door lock switch.
I will have to make one of your events.
z proud is offline   Reply With Quote
Old 05-20-2010   #7
secondchance
Could you elaborate?
Old 05-20-2010   #8
QB93Z
QB93Z's Avatar
.....I will have to make one of your events.
You are welcome anytime!!!
We will give you a nice WAZOO Greeting.
Old 05-20-2010   #9
QB93Z
QB93Z's Avatar
I will schedule a WMD for the 29th.
Old 05-20-2010   #10
secondchance
Um... I just found out I may have to fly to Toronto on the 29th...
Sorry, Jim. Following week?
