Old 05-06-2010   #1
tpepmeie
Default FS: 8 custom CP pistons 4.125 bore
I have a set of CP Pistons for 4.125 bore. These came without valve reliefs, so I had to order a second set for my motor. These are the "X-forging" very lightweight design. They would work great with a 4.000 stroke and 6.000 rods. CH=1.025. These are almost $700 wholesale/$1k retail. No pins or rings.
>> PRICE REDUCED << $400.
Old 05-07-2010   #2
VetteVet
VetteVet's Avatar
Default Re: FS: 8 custom CP pistons 4.125 bore
Todd,
I might be interested. Can you provide specs on the dish volume and ring sizes?
Old 05-08-2010   #3
tpepmeie
Originally Posted by VetteVet View Post
Todd,
-17.6 cc dish volume. 1.2mm/.043/3mm ring pack.
Old 11-30-2013   #4
tpepmeie
TTT. These need to go to a new home. Surely somebody in the FBI crew is thinking about a AES big-bore motor. These are perfect for it.
Old 11-30-2013   #5
pantera1683
same price?
pantera1683 is offline   Reply With Quote
Old 11-30-2013   #6
Any other configurations besides a 415?
Old 11-30-2013   #7
cvette98pacecar
409 with 3.82 regrind.
Old 11-30-2013   #8
tpepmeie
So, lots of guys asking about compatibility. These are 1.025" compression height.
figure the stock deck height is 9.025"
(stroke /2) + Rod length + 1.025" = 9.025
I use these with a 4" stroke and 6" rods, so
(4/2) +6 + 1.025 = 9.025
You could figure out other combinations.
Old 11-30-2013   #9
tpepmeie
could also do a 3.75" offset ground crank, with 6.125" rods.
Old 12-01-2013   #10
tpepmeie
Price reduced to $500. These need to go, or I might have to build a big bore 401
