Old 05-03-2010   #1
Default DOHC comes back?
Anyone see the new Ford Mustang GT has a 5.0 that is knocking out 412 NA HP @ 6500? That equates to a 12.8 @110....not bad...will be interesting to see more specifics as the engine comes out.
Wonder if there any ideas we can steal?
PS Pete it has electric power steering
Old 05-03-2010   #2
Kevin
Kevin's Avatar
Default Re: DOHC comes back?
fords been running dohc in mustang cobras since 96 and sohc in mustangs also since 96...I think the sohc came in the crown vic around 93-94ish? I love the new mustang
Old 05-03-2010   #3
I know that, but they have not come close to 400hp without forced induction......fuel economy is better than the 3 valve 4.6....K&N did an independent test of the motor, coming up with almost 440hp.
Electric power steering:
http://www.flamingriver.com/index.cf...rod/prd479.htm
Old 05-03-2010   #4
Kevin
Kevin's Avatar
this is true, the new 5.0 is going to be a beast.
Old 05-03-2010   #5
DOHC Moostang... I love it! May it light a fire under Corvette!!
P.
[I][COLOR="Blue"]Good carz, good food, good friendz = the best of timez![/COLOR][/I]
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 05-03-2010   #6
http://50mustangsuperfords.automotiv...ech-specs.html
5.0 Tech Specs
5.0 4V TiVCT V-8
First Model Year 2011
Engine Family Modular
Code Name Coyote
Displacement 4957cc (302 ci)
Bore x Stroke 92.2 x 92.8mm (3.263 x 3.647 inch)
Horsepower
  • 412 hp @ 6,500 rpm, 91 octane
  • 402 hp @ 6,500 rpm, 87 octane
Torque
  • 390 lb-ft @ 4,250 rpm, 91 octane
  • 377 lb-ft @ 4,250 rpm, 87 octane
Shipping Weight 430 pounds, includes water pump
Block Low-pressure cast 319 aluminum, pressed-in thin-wall iron liners
Bore Spacing 100mm (3.937-inch)
Deck Height 227mm (8.937-inch)
Deck Thickness 13mm (0.510-inch)
Cylinder Head Retention 12mm bolts, 4 per cylinder, 10 bolts total per bank
Oil 5W/20 weight, mineral
Oil Pan Stamped steel, 8 quarts
Windage Tray Integral w/oil pan gasket
Oil Pump Gerotor
Pistons Hypereutectic, short-skirt, flat-top w/four equal valve reliefs; moly friction-reducing coating; oil-jet cooled
Piston weight 500 grams
Piston Pin Full-floating, 22mm diameter
Piston Pin Retention Wire lock
Piston Rings 1.2 x 1.2 x 2.5 mm, moly top ring
Connecting Rod Powered metal forging, I-beam, no balance pad
Connecting Rod Length 150.7mm (5.933-inch)
Rod/Stroke Ratio 1.62
Crankshaft Forged steel, fully counterweighted, induction hardened
Main Journal 67.5mm (2.652-inch) diameter
Rod Journal 53.0mm (2.082-inch) diameter
Flywheel Retention Eight-bolt
Cylinder Heads Aluminum, four-valve per cylinder
Head Bolts 12mm, four per cylinder
Valve Covers Composite
Compression ratio 11.0:1
Valves 37 x 31mm (1.454 x 1.218-inch), four per cylinder
Camshafts DOHC, four camshafts, independently adjustable timing
Camshaft Timing Twin independent variable
Duration 260 degrees intake, 263 degrees exhaust
Lift 12mm (0.472-inch) intake, 11mm (0.432-inch) exhaust
Lift Limit 13mm (0.510-inch) physical limit in head
Valve Followers Roller-finger follower
Lash Adjusters Hydraulic
Coolant Organic (red)
Exhaust Manifold Short-tube, S44100 stainless-steel Tri-Y tubular headers; 10mm mounting studs w/prevailing torque nuts
Intake Manifold Constant cross section, long-runner single-plane (single-scroll); molded composite w/upper section colored; front throttle body mount
Throttle Body Single-blade, 80mm, e-throttle
Engine Management Software Copperhead
Mass Air Meter 86mm, digital
Oxygen Sensors Universal Exhaust Gas
Knock Sensors Two, in block valley
Ignition Timing Crank trigger, rear of crankshaft
Ignition Coil-on plug
Spark Plug NGK Iridium
Firing Order 1 5 4 8 6 3 7 2
Cylinder Numbering
  • Right bank: 1, 2, 3, 4
  • Left bank: 5, 6, 7, 8
Fuel System Port fuel injection, returnless
Fuel Injectors 32.8-lb/hr
Fuel Pressure 55 psi
Fuel Requirement 87 octane minimum, 91 octane best/rated power
Old 05-03-2010   #7
bb62
bb62's Avatar
Modular V8 came online for the 1991 model year.
bb62 is offline   Reply With Quote
Old 05-04-2010   #8
Direct Injection?
Old 05-04-2010   #9
Nope, direct injection was not in the budget.....although casting is set up for it down the road.
Old 05-04-2010   #10
Aurora40
Aurora40's Avatar
Equally impressive is their new V6 that makes 305hp and gets >30mpg on the EPA's 2008+ highway test. You can get a 300hp 6-speed manual and a warranty for about $23k sticker.
They also have a V6 performance package that adds the GT suspension, but it isn't out yet. I assume you could get that on a base coupe for a real performance bargain, but who knows.
Bob Saveland
Former Owner of #2517
