Old 04-30-2010   #1
todesengel
Default Few ?'s for the true guru's on the forum
What type of triggering system is used on the LT5?
Specifically, does it have a crank sensor or cam sensor? How many pulses or teeth are on the crank and or cam sensors?
todesengel is offline   Reply With Quote
Old 04-30-2010   #2
Default Re: Few ?'s for the true guru's on the forum
there are both Cam and Crank Sensors.. Cam sensor is for injectors
cranks sensor runs the DIS, there are 9 notches on the Crank sensor.. 9th denotes location..
Old 04-30-2010   #3
todesengel
You sir are the man. Thank you!
Old 04-30-2010   #4
phrogs
phrogs's Avatar
Then there are also differences in the DIS module If you have a certain pat number you need a spacer for the crank sensor.
JOHNNY P
Currently own
phrogs is online now   Reply With Quote
