Old 04-23-2010   #1
Default C6 Z06 wheel alignment
Having recently put on C6 Z wheels and tires, Pete was good enough to also give me a set of lowering bolts. Installed those last weekend so it was time to check and re-do alignment if necessary. Took ZR to Suburban Tire on Lake Street in Hanover Park. Ralph does the alignments with an awesome Hunter machine. Ralph is a Corvette brother,
being the owner of a Briar Blue/Black 1972 LT-1. He added Brodix heads.
Goes without saying, Ralph "appreciates" Vettes and Vette owners.
I would HIGHLY recommend using him for your alignment if you are in the neighborhood. Excellent and THOROUGH service. Ralph took over 2 hours doing the front and rear. Rear wasn't too bad. Fronts were off by 1 and 1.8d. Did a great job. A posting a picture of him and of the before/after alignment specs from the Hunter. BTW, the cost for this was $113. Super.
We used JeffVs street handling spec as close as we could get. Got camber back near spec. Turn in seems more responsive. Tracks nicely!
Old 04-24-2010   #2
Default Re: C6 Z06 wheel alignment
was was not too bad to begin with.. mine was pretty bad when I got it done last year..
Although I went to the place Marc H takes his.. I will go to Suburban next time
Old 04-24-2010   #3
=Jeff=,
Not sure if front end was off due to diff wheel offset or if it was due to crap job by NTB shop at Stratford Square last year.
Old 04-24-2010   #4
well it was not off by too much..
Old 04-24-2010   #5
Ralph thought it was off and that it tracked ok because left and right offset each other.
Old 04-24-2010   #6
Pete
Pete's Avatar
Pictures????
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 04-24-2010   #7
Originally Posted by Pete View Post
Pictures????
Pete
Of?
Just determined my winter project. Upper ball joints. Rubber boots ripped on driver and passenger side.
Old 04-24-2010   #8
Of?
Winter?
that one is actually pretty easy..
Old 04-25-2010   #9
Pete
Pete's Avatar
Of?
You in a thong on your Z licking a lolipop.
Pictures of your Z with it being lowered and alinged,of course.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 04-25-2010   #10
Of?
Like =Jeff= said...Easy.
Just gotta grind/drill out the rivets and the new ball joints (got mine from midamerica) come with bolts. Then you can take your Z back to the alignment shop (again) and get those pictures Pete wanted. (No, not you wearing a thong, silly. I mean pix of the alignment process...sheesh!)
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
