Old 04-19-2010   #1
xxxscimitarxxx
Default Will C5 brake rotors fit
Hi to all
trawled threads for a perfect answer to this Q and cant find so here goes
Ive noticed my rotors have become quite pitted and I have a line on a set of clean C5 rotors from a 2001 manual coupe in the UK ..but without callipers......
Q1...can the rotors directly replace front and rear 92 zed stock items, and can l continue to use the stock callipers......
Or is there other work to do ?
Dave
xxxscimitarxxx is offline   Reply With Quote
Old 04-19-2010   #2
Default Re: Will C5 brake rotors fit
Dave, I do believe that swap will not work. C4 rotors are a smaller diameter?
I confess that I'm not 100% sure on this, but I know to do a C5 front conversion to a C4 you need different caliper mounting brackets. A C5 caliper is larger than a C4 ZR-1 caliper, and I do believe a C5 rotor is larger in both diameter and thickness than a ZR-1 C4 rotor.
Old 04-19-2010   #3
xxxscimitarxxx
Thanks for that tom......l was guessing it wasnt going to be a straight swap....may just as well get what fits first time....something that utilizes the stock hub/caliper but with added stopping
Old 04-19-2010   #4
Aurora40
Aurora40's Avatar
It's really unlikely it would clear the caliper mounting bracket. That thing sits pretty close to the stock rotor on both sides, and the C5 rotors are .15" thicker.
Bob Saveland
Former owner of #2517
