Old 04-17-2010   #1
xxxscimitarxxx
Default 200mph ???
I suppose this is a tech area question so here goes.......
basically what would it take to hit 200mph (apart from a mountain side and dropping out the back of a plane)
the C4 Zed is tantalisngly close to this number but has anyone done it or can it be done, and what would it take
xxxscimitarxxx is offline   Reply With Quote
Old 04-17-2010   #2
Aurora40
Aurora40's Avatar
Default Re: 200mph ???
Doing the math, if you assume a 385hp Z can hit 180mph with stock gearing (I used 385 because I'm not 100% positive every factory Z could hit this speed), then that's 6230 rpm, and the drag force would be 325c lbs, where c is a constant I don't feel like figuring out.
To hit 200mph, using the formula Fd = 1/2 p v^2 Cd A, you would need 400c lbs of force. Since this would happen at 6950 rpm with stock gearing, you would need to make 530hp to match the drag force at 200mph.
That's a lot of extra juice for 20mph!
Old 04-17-2010   #3
bdw18_123
Curtis Ward was supposed to have done 201MPH in a stock 91 ZR-1 with the only mods being lowered by 1-inch and some mods to the front airdam (don't know what they were). I'm not the one who put the text in the picture.
Old 04-17-2010   #4
IowaZR-1
IowaZR-1's Avatar
2002 BBORR radar results show no car #364 or a owner /driver named Curtis Ward
http://www.bborr.com/2002/2002radar.html
IowaZR-1 is offline   Reply With Quote
Old 04-17-2010   #5
bdw18_123
That's weird, I don't know what's up with that. I got the info from WB9MCW, he knows more about it than I do.
Old 04-17-2010   #6
Kevin
Kevin's Avatar
i can't remember the year exactly but it was shortly before the car was put into the wall at the BG autocross. that was a hell of a car
Old 04-17-2010   #7
Locobob
Perhaps he is not listed because he got disqualified
Robert
Old 04-17-2010   #8
Sgreg
Sgreg's Avatar
Is that 530 gross or RWHP ? 530 Rear wheel HP would take a stroker for sure.
Sgreg is offline   Reply With Quote
Old 04-18-2010   #9
IowaZR-1
IowaZR-1's Avatar
this link talks some about "Sledgehammer" and the new ZR1 going after the Veyron record top speed
http://www.team-bhp.com/forum/intern...ke-veyron.html
Old 04-18-2010   #10
xxxscimitarxxx
well that answered some thoughts.....
thank you guys
so baiscally with either
some ''seemingly'' simple aerodynamic changes (lowering and front air flow mods.... duct tape + remove wing mirrors + A GOOD WAX) its possible with enough straight track to do it almost stock
and or
520 bhp
guess my next question is how much track would you need (or german autobahn )
you might be guessing by now that lm looking for a personal challenge in my old age....which could also result in not getting any older
(Aurora40.....do you do those kind of calcs for a living)
