Old 04-13-2010   #1
ZR1ROB
Default What is causing this oil smell?
I cant find any obvious leaks, and there is no spotting on the floor under the car when parked. If its burning oil, its so small an amount that I cant see a noticable dropping of oil level on the dipstick.
Yet every time I'm at a stoplight or after parking, I can detect a distinct oil burn smell around the car.
I changed the PCV valves, but thats all I've done. I'm stumped. Anyone want to chime in?
ZR1ROB is offline   Reply With Quote
Old 04-13-2010   #2
QB93Z
QB93Z's Avatar
Default Re: What is causing this oil smell?
I saw this effect happening recently. It turned out to be a small cam cover leak that was dripping on the header. The oil burns off and never reaches the floor of the garage but you sure can smell it.
If this is happening on your car, you will see obvious staining on the header or exhaust manifold.
Good luck.
1990 Black ZR-1 - sold
1993 Quasar Blue ZR-1
1994 Competition Yellow ZR-1
1995 Dark Purple ZR-1
Maryland State Coordinator
Old 04-13-2010   #3
Pete
Pete's Avatar
Also check header center stud,common issue & easy fix.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 04-13-2010   #4
Future bad cat?
