![]() Join Date: Jul 2007
Apparently do not work....
here is direct bolt up: ![]() here is an added 2.37mm: ![]() the corner edge of the caliper is catching on the center section of the wheel.. a 2.37mm washer works for clearance and I was thinking of a 5mm Spacer.. but is that enough? or will I be better off looking for J55 Calipers again.. Anyone have any J55 Calipers and Abutment brackets? I found a good price on Rotors and would get new pads..
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - Flowmaster Cats - Borla Catback Late Model IH - Plenum Coilovers - 4.10s Shelby Series 1 - Wilwood Brakes Custom Interior NCM Lifetime Member #978 Last edited by -=Jeff=-; 04-11-2010 at 07:33 PM. |
You need to ask Al about that, if I recall he unbolted the centers and turned them around somehow.
H ![]() |
Hans,
I think Al has Wilwood brakes. Jeff, I still have my old calipers. |
I talked to Al already about this, moving the center section to the outside will make it worse for me.
Dominic, How much for the Calipers and Brackets, as much is I would like to keep the C5 brakes, I am thinking that maybe the OEM will cause less headaches I found a deal on Rotors, I just need Calipers and Abutment brackets
I see... can you use a spacer (adapter) to move the wheel farther out?
H ![]() Last edited by Ccmano; 04-11-2010 at 12:29 PM. |
#6 | |
I bought a set of 5mm Spacers as the 2.37mm washers I tried allow for clearance.. so I thought 5mm should be good, but how much movement occurs with the wheels turning and caliper float... since the Shelby wheels are designed for the J55s maybe I need to swap back.. then sell the C5 stuff.. 1 step forward but 2 steps back ugh..
![]() Join Date: Jan 2004
Unbolt the wheel centers and move then from inboard to outboard, add a 1/4in spacer = problem solved. Looks like this and clears my 4 piston Alcons no problem.
Robert ZR-1 Net Registry Oregon State Director 91 ZR-1 #431 Black/Black LPE 368 |
Parking lot filled with ZR-1's, nice!!
#9 |
I love how your car looks Rob.... great stance!
#10 |
Rob,
what purpose does moving the center to the outside do for the clearance? is it because you are moving them out it keep them from sticking out? I have .310" spacers and ordered .200" spacers. I was going to try the .200" spacers first With either will I need longer studs?
