View Poll Results: Which aftermarket Flywheel do you have?
Centerforce 1 1.92%
DRM 2 3.85%
Fidanza 45 86.54%
Jeal Enterprises 1 1.92%
McLeod 3 5.77%
Voters: 52. You may not vote on this poll
Old 11-29-2005   #1
Z Factor
Z Factor's Avatar
Default Which aftermarket Flywheel do you have?
For those of you who have changed to a lightweight flywheel, which one did you install?
Old 11-29-2005   #2
Patton
Patton's Avatar
Default Re: Which aftermarket Flywheel do you have?
Great thread, I have been wondering about this too, and if you did install a lighter flywheel, how did it effect driveability/RPM responsiveness? Also, Might I add, has anybody here installed lightweight/carbon fiber drive shafts?
Patton is offline   Reply With Quote
Old 12-09-2005   #3
Me got da BIG F in mine and scored the whole pkg from these guys. Very happy with the clutch/flywheel perf. improvement, but I do get the famous "gear rattle" off the ZF tranny...the clutch is a stage 1 ceramic I think. Tell em boys just what ya need and they will hook u up & gud $ deal too!
http://www.carolinaclutch.com/
Old 02-16-2008   #4
bradslt5
fidanza here also with the ceramic disc . love it on the street. at the strip its picky .either bog or cook the tires ight think of trying a little heavier one for my black car since its going to become a dedicated drag car. other than that its a very cool mod
Old 02-16-2008   #5
Jagdpanzer
Jagdpanzer's Avatar
Is it a good idea to go with a spring hub clutch disc with the Fidanza FW?
Old 02-16-2008   #6
Jeffvette
Yes, it helps take some of the noise out.
Old 02-16-2008   #7
Using 11" Camaro LT-1 sprung hub disk with mine.
Old 02-26-2008   #8
One has Billy Kirchoffers FW-PP and clutch
The other has a stock set-up.
Old 02-26-2008   #9
Fidanza, with Spec stage 2/3 hybrid combo disc. Don't forget to install those special PP bolts with aluminum flywheels from Ron Wood, for safety's sake.
Old 02-26-2008   #10
Jagdpanzer
Jagdpanzer's Avatar
I understand most after market clutch companies use the the same pressure plate supplier but how would those with expirience rate the spring hub clutch discs avalable from Centerforce, Spec, Mcleod, Corolina Clutch or anyone else I may have missed for general street use with the usual Z mods (headers, SS exhaust, chip, 4.10s, p&p intake,AL Fidanza flywheel)?
Seems the Mcleod disc JeffVette was mentioning a while back is no longer being produced.
