Old 03-21-2010   #1
Jagdpanzer
Jagdpanzer's Avatar
Default Potential Sources for New Lifters
Researching potential sources for new lifters to the original GM PN 17120991 lifters from AC Rochester our engines were originally built with.
Discovered the same style bucket lifter is also used in the GM Quad 4 engine as well as some foreign engines built by Audi VW and others.
Here are the aftermarket alternatives I've identified so far:
  • Current AC Delco HL110C
  • Milling JB-6051
  • Federal Mogul Sealed Power HT2236
  • Clevite 213-1747
Prices range from less than $10 to over $30 each.
Anyone care to share their experiences with any of these?
Particularly interested how they compare with the original GM lifters in terms of performance and durability.
Thanks,
Phil
Old 03-22-2010   #2
tpepmeie
Default Re: Potential Sources for New Lifters
Phil,
another option is the lightweight VW/Audi lifters made by INA. Stock GM/AC Delco pieces are heavy...about 75 grams each. The INA ones are less than 50 grams. We have a set to test with my new cams on the spintron to ensure they are reliable to at least 8000 with my valvetrain pieces. (No, Kevin, I'm not really going to spin my motor that high....)
The installed height would have to be checked thoroughly if using stock valves and valve stem height. In my case, it stacks out perfectly with my new valves, but your mileage may vary.
They're about $12 each.
Todd
Old 03-22-2010   #3
Jagdpanzer
Jagdpanzer's Avatar
Thanks Todd,
Great tip!
Keep us posted on how they test out.
Old 03-22-2010   #4
Polo-1
Todd
That's OK mine is chiped to 8,200
had a little set back, did not hold water pressure. GO BIG or reWELD
Old 03-23-2010   #5
tpepmeie
Uh oh. Does that mean the rest of us will have to wait even longer to get our parts done? No cutting in the line, Kevin
Todd
Old 03-23-2010   #6
Locobob
Don't worry about it Kevin, just puncture the others and call it water injection.
Robert
Old 03-23-2010   #7
Locobob
Phil,
Todd
Why would you need to check the installed height? Specs somehow different? Are your valves not stock height? I'm guessing that you looked into hardness compatability?
Be awesome if the VW/Audi lifters work, $12 and 25g lighter - whats not to like.
Robert
Old 03-23-2010   #8
Polo-1
already fixed and in the mail back home
Old 03-23-2010   #9
tpepmeie
There is less than 1 mm difference in uncompressed foot to face distance. Which is still a lot, really, considering the lifter travel is .120". Hard to tell exactly how that difference would change with oil pressure, but I suspect not much. Works fine for me, perfect in fact, because I have +1mm valve tips.
Nope, a mm longer tip. Originally designed it that way to leave room for a shim under solid buckets, and get taller spring installed height. The solid bucket idea faded away, but it fortuitously turns out that the VW lifters are a perfect fit with my combination. The valve seat cut might have had a small interaction here with the stackup height, but relatively small I think.
Yep. No worries there.
Old 05-22-2010   #10
HAWAIIZR-1's Avatar
Phil,
Thanks for asking this question as I am looking for some new lifters right now. I am thinking of going with the HT-2236 Sealed Power and hope someone can chime in about their experience with these or what they have heard. I have to search my old, old list server emails as I remember something mentioned about 5 years ago or so.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
