![]() Join Date: Aug 2006
I am interested in knowing if anyone with plenum, inj. housings and head porting mods has made mild modifications to the cams. This assumes a stock 350 cu. in. LT-5. Trying to determine if regrinding can enhance performance of a stock cube, ported motor or cam timing is a better way to proceed.. Jump in if you have experimented with cams without cubic inch changes.
that would be Pete
![]() Join Date: Dec 2003
I have seen a gain of 20-25 RWHP
It showed on 2 different dynos and trap speed at 2 tracks. Before regrinds i was making 440-449 RWHP 400-405 RWTQ (stock cams) After regrinds i make 469-474 RWHP 395-400 RWTQ Cam Specs Intake .236 .425 Exhaust .220 .415 The above HP/TQ #'s are from lowest to highest Let me also add i did not loose much if any power at low RPM they are withen 5 which i would consider none. If you come to BG you'll be able to see,hear and feel throttle response on my Z and decide for yourself. Idles nice at 850 not too cammy and drives like a stocker. Pete
'91 #1635 PoloGreen 350 LT5 11.09 @ 129.27 11.04 @ 128.86 474RWHP 400RWTQ http://www.youtube.com/watch?v=SFNFOhGGlR4 http://www.youtube.com/watch?v=ZlRIOMwaDYY https://sites.google.com/site/peteszr1garage Last edited by Pete; 03-18-2010 at 03:27 AM. |
#4 | |
You are da man!!!!!!!!!! ![]() David |
#5 | |
Sounds great and I'll look for Pete at BG. How much are we talking and where is the source? Thanks!
#7 | |
Pete, Was the original 440hp just your basic top end and head work? Were the stock cams degreed differently than spec? |
#8 | |
440 is same as 449 no change i had it on 2 different dynos and as always second pull makes less then first. They are from lowest to highest. Cams were not stock timing. Pete P.S. The people that do the cams are a bit pricey but i know they work if anybody has them done cheaper let me know how they work i'm done with cam R&D it starts to get expansive. Regrind $300 each
#9 | |
#10 | |
![]() Join Date: Nov 2007
Who is going to port your heads, Dom? The head porting (as Ryan so often reminds us) begins at the valve seat and works back, as you well know. Just curious if you were going to tackle it, cuz porting is (to me) a fascinating subject and I'd be curious to know what your specs are going to be. P. |
