Old 03-15-2010   #1
jrd1990zr1
jrd1990zr1's Avatar
Default Getting Hosed
Got the top end of my 1990 pulled apart and got to thinking about the 20 year old radiator hoses. They are not cracked or dry-rot, actually look pretty good.
First question should I replace 20 year old hoses before a 1400 mile trip one way to BG??
Second, if I decide to replace them what is a good replacement and source?
Comments please! Thanks
Old 03-15-2010   #2
Default Re: Getting Hosed
John,
Do the hoses look good? If so I wouldn't change them....
Also if you do decide to change them, I would go with OEM hoses rather the Samco ones.
Old 03-15-2010   #3
cuisinartvette
20 is old, they can look good from the outside but be ready to fail from within.
Have used the samcos they are Ok. If I had to do it over Id use rubber, opinions will vary. Youll want to buy the stainless smooth clamp kit if you get the samcos.
Old 03-16-2010   #4
PhillipsLT5
PhillipsLT5's Avatar
I have the samco's with correct clamps and they smell, antifreeze, but no leaks, smellco, go with rubber
Old 03-16-2010   #5
tf95ZR1
tf95ZR1's Avatar
Hey, but the Samcos look good in whatever color you want!
And only for about $190, an hour or two work, and bloody knuckles!
Old 03-16-2010   #6
John, your call on the hoses, but age is age.....your call..
However, if you do any replacing.......Do Not Throw Out the OEM clamps!!!
I know they are a royal PIA to work with, but any hose will "leak" under the thermal changes of the aluminum if the sprung steel OE clamps are not used. The reason for our PIA clamps is so that they react with the metal under heat load cycles, that is something that an ideal clamp can not do! I do believe that those sprung steel clamps were an answer in a TSB as I think they started with ideal type clamps and had coolant odor complaints.
Been there & done that and the smell drives me nuts...along with checking all the hose clamps every now & again. Some day I will try to find all the OE clamps to replace the ideal clamps.
Old 03-16-2010   #7
Aurora40
Aurora40's Avatar
If I had it to do over again, I'd get GM rubber hoses vs Samco. I'd also probably change them even if they look good. The age would just worry me. Though it may be unfounded.
Old 03-16-2010   #8
lbszr
lbszr's Avatar
Sounds like maybe the clamps are the issue. I've had the opposite experience. My old oem hoses seaped at the connections with oem clamps. The Sampco hoses haven't leaked at all for 4 years with oem clamps and no smells either, just a rubber smell, but that's coming from the rear of the car somewhere around the lugnuts
Old 03-16-2010   #9
Age is the factor, Yes I would replace them. Samcos are a good choice but make sure you buy the clamps as well. Love mine
Old 03-16-2010   #10
VetteVet
VetteVet's Avatar
This might be the solution to the clamp dilemna. We use these clamps in the marine industry. They are spring loaded and compensate well for size variations due to wide temperature ranges in fluid systems.
http://www.breezeclamps.com/ct.htm
Has anyone tried using these yet on their cooling hoses? I'm willing to give them a shot, but it wouldn't be until I get my engine back together and in the car.
Jep
