Old 03-11-2010   #1
902066
Default Welding Cat-Back Exhaust.
For those of you who have welded your exhaust to keep the tips from turning. I have Stainless Works headers and Flowmaster cat-back, tired of the muffler tips not staying straight no matter how tight the clamps are.
How many of the connections do I have to weld? All of them? Just the last two,[exhaust pipe out of resonator, and muffler]? Or do you just weld the last junction, [the mufflers]?
Lastly does the weld have to be all the way around the pipe or just tac welded in 3 or 4 spots per joint? Thanks
902066 is offline   Reply With Quote
Old 03-11-2010   #2
jonszr1
jonszr1's Avatar
Default Re: Welding Cat-Back Exhaust.
on my flowmaster system i just tacked in 3 places on each pipe .i tacked where the mufflers connect to the exhaust, and the connection just before it gets to the rear end
Old 03-12-2010   #3
Bob G
Weld all connections . You just need to weld 1/4 to1/2 inch in one spot to keep it from turning . It would have to break the weld to move.
Bob G is offline   Reply With Quote
