Old 03-08-2010   #1
Toyvet1
Default Battery drain
This past month I started having a battery problem. If the car sits over night the battery is drained. Ive check all the lights and other normal things.
Over thew winter I had the whole stereo replaired by Dr Don, pleniumn pull to replace injectors and coils . Never had this problem before I did the work. The battery was only 8 months old and got a replacement so I dont think its the battery. So where do i start any ideas?
Its a stock 1990.
Toyvet1 is offline   Reply With Quote
Old 03-08-2010   #2
Default Re: Battery drain
Charge up the battery and leave it sit disconnected over night and see if it maintains charge
You have "Align Center" You want "Align Left"
Old 03-08-2010   #3
QB93Z
QB93Z's Avatar
Start by checking the courtesy lights. They can stay on if a door switch in not working. Check the center console lid closes all the way so the console light turns off. Check the map light located in the rear view mirror. It is operated by a switch on the lower edge of the mirror.
Get a volt meter that can measure current. (You can buy an inexpensive multi meter) Disconnect the battery negative terminal. Connect the current meter between the battery terminal and the negative cable. The reading on the current meter is the current drain from your battery. It will probably be just a few milliamps. Now, in the fuse panel inside the passenger door, pull the fuses one at a time and look at the current meter. When you pull the fuse for the problem circuit, the current drain will drop to zero. Now you know where to start looking for the problem.
Good luck
1990 Black ZR-1 - sold
1993 Quasar Blue ZR-1
1994 Competition Yellow ZR-1
1995 Dark Purple ZR-1
Maryland State Coordinator
Old 03-08-2010   #4
Good luck
What about the secondary fuse holders under the hush panel on the passenger side?
Old 03-08-2010   #5
QB93Z
QB93Z's Avatar
What about the secondary fuse panel under the hush panel on the passenger side?
I have never had to look at that fuse panel. What circuits are fused there?
Old 03-08-2010   #6
Default Help on the way, ol Buddy!!
Have tools...Will travel!
PM sent.
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 03-08-2010   #7
Default Re: Help on the way, ol Buddy!!
PM sent.
P.
That's what I'm talkin about!!!!!!!!!
Class Bro's!
Old 03-08-2010   #8
Toyvet1
Thanks guys , I wont be able to touch the car till the weekend. Ill do a little research till then.
