Old 03-07-2010   #1
jrd1990zr1
jrd1990zr1's Avatar
Default Extra mouse power
Pulled the plenum look what I found by the starter. Looks like the past resident dined on the purple wire to the starter.
I have been thinking that I can use some heavy shink tube then cover with liquid electrical tape. Any better suggestions on a repair?
Since I am at this point should I just go ahead and pull the injector housings to clean them up. The more I remove the easier it seems to get into the area for clean up. Thoughts?
Old 03-07-2010   #2
jrd1990zr1
jrd1990zr1's Avatar
Default Re: Extra mouse power
Thanks for the reality check.
BTW already pulled the starter and started the clean-up of the drain.
Old 03-08-2010   #3
flyin ryan
flyin ryan's Avatar
Is that purple wire 'Fuseable link' wire? On a lot of GM's it was...If so maybe it just got warm a time or two
Old 03-08-2010   #4
jrd1990zr1
jrd1990zr1's Avatar
Don't think it is the fuseable wire. Way it is chewed looks like regular wire.
Anyone know the number or know where I can obtain the corrrect metal connector # for a replacement? I've got the plastic weather pack connector intact.
Thanks, John
Old 03-08-2010   #5
Oh..ya....get some mouse bait in your garage
Old 03-08-2010   #6
jrd1990zr1
jrd1990zr1's Avatar
This nest was there for a long time. The scary part is that this was in there from the previous owner who stored the car in an unheated garage under his house. I drove the car twice to Carlisle, last year and the year before. I am glad I found it before the trip to BG, my luck the bare wire would have touched off the nest on this long of a trip.
Thanks for your advice!
Old 03-29-2010   #7
xxxscimitarxxx
a few poison pellets in the plenum void .....last line of defense
xxxscimitarxxx is offline   Reply With Quote
Old 03-29-2010   #8
Default All too familiar...
Right out of the bag, my Z had a missing issue, especially before it got good and warm. Turned out to be mice had nested on top of the coil pack and had chewed the plug wires. (My coil pack area and the valley under the starter looked zackly like your motor! BTDT!
I live out in the country; surrounded by countless field mice. Come the first frost, and oh boy! The battle is on! My first winter on the place, I thought I was going to be run out of the place - they were everywhere - caused some major damage to a couple cars (wiring and ruining carpet, etc.).
Forget about Decon...When I would find turquoise-colored poop on my console and on top of the plenum and that unmistakable odor, I knew I wasn't getting a handle on it- verified by the fact that trap activity was still on the increase.
I've told this before, but on recommendation from a feed store owner I bought this stuff called "One Bite"; saved the day and my sanity! (Or, what was left of it) I break up a package of it and spread it around the garage in places where my pooches cannot get to it, and for safety I put a piece under the seats of the vehicles. Then I load up the interior with Bounce dryer sheets and stuff some between the runners of the plenum (leaving enough sticking out so I can pull them in case I'm going thru Z withdrawals).
I leave the stuff in the garage all year, but before the first freeze, I'll reload. Far as I can tell, this past winter (and a doozy it was!) we had NO mouse issues at all that I have been able to detect.
Hope this helps someone!
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 03-29-2010   #9
hiperf406
hiperf406's Avatar
I've used a product from a local farm supply store called "Fresh Cab" in my vehicles. Doesn't smell bad at all but mice must not like it & cleanup is a cinch as it is in individual packets. Seems to work good so far no problems. Could even put a packet under hood as well as in all interior compartment.
lorne # 1748
Stock except for a modified Corsa exhaust.
When the flag drops the bull sh1t stops!
hiperf406 is offline   Reply With Quote
Old 03-29-2010   #10
jonszr1
jonszr1's Avatar
another fix is to buy a couple of bars of irish spring soap and break them up and pu them in the interior of the car mice hate that stuff . also while you have the plenum off ck the bolts on the pvc vent pkg . in the center they are typicly loose
