Old 03-04-2010   #1
Ccmano
Ccmano's Avatar
Default Differential Lube addative?
I'm about to swap in the new 4.10 pumpkin next week and getting all my misc. supplies ready.
I've read that the new synthetic differential lubes like Mobile 1 and Amsoil do not require the clutch addative from GM? Can anyone confirm this? Any experience out there of running these lubes without the addative? Or should I just play it safe and get the stuff from GM.
Any special gasket cement for the cover or will RTV work?
Any other tips?
Thanks
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 03-04-2010   #2
rebelz
rebelz's Avatar
Default Re: Differential Lube addative?
On the Mobil 1 web site, it says that their LS 75W90 gear oil contains friction modifiers for use in limited slip differentials... I used the lube, I added a bottle of the GM stuff when I did the service last spring. No issues, 12,000 miles normal & spirited driving, including drag racing and autocross.
The other one I can't speak about, as I don't know.
Rich
REBelZ
'92 ZR-1 Yellow/Black #031
rebelz is offline   Reply With Quote
Old 03-04-2010   #3
Pete
Pete's Avatar
Hans,add the additive (1 bottle)
Last year i went with Amsoil and they also mention no additive needed but it did,the rear end was crowling for it i put in one bottle and all is quiet again.
Now i always have it on hand,come by and pick one up.
Oh i forgot you moved away far far away.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 03-04-2010   #4
Jagdpanzer
Jagdpanzer's Avatar
I also use the Mobil 1 synthetic rear end oil and the GM additive.
Not sure if its really needed but felt it wasn't worth the gamble nor did I want deal with hassle of putting it in later.
Old 03-04-2010   #5
flyin ryan
flyin ryan's Avatar
I used GM's Dexron, no additive.
Old 03-04-2010   #6
xlr8nflorida
xlr8nflorida's Avatar
I have Mobil 1 as my rear end oil.
Gordon K. suggests 2 bottles of GM additive.
Per Mobil it should be fine with no additive however, I added 1 bottle in my car.
