Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 ZR-1 Prototypes (pre-production)
Old 03-03-2010   #1
vettebrett
Default New Paper work from Early Cars
OK, here is some early stuff that I have had for years about the 89 ZR-1 from the C P C Engineering Dept
If anyone wants copies of these just email me at corvettechallengeregistry@comcast.net and I will send them out.
vettebrett is offline   Reply With Quote
Old 03-03-2010   #2
vettebrett
Default Re: New Paper work from Early Cars
Old 03-03-2010   #3
vettebrett
Old 03-03-2010   #4
1989ZR1#74
Good stuff Brett. thanks.
I like how they say the LT5 is available with coupe or convertible, but the wider wheels are only available with the ZR-1 option. So in 11/87 there where two options. ZR-1 and LT5.
1989ZR1#74 is offline   Reply With Quote
Old 03-04-2010   #5
bdw18_123
I noticed that too, very interesting. So I guess, if this plan had gone through, you could have ordered a standard C4 (coupe or vert) with just the LT5. I wonder what the VIN number for those cars would have been?
Old 03-04-2010   #6
That is some cool stuff Brett! It almost looks like GM was going to let the customer do some mixing & matching? Coupes & verts and ZR-1 or just an LT5. I just can't see the stock size tires living very long behind an LT5.
I love reading the "engine description"....it reads like a who's who of all the good ideas you should use when building a mouse motor. I just want to know what happened to the "larger radiator" we were supposed to have?
Thanks for posting this stuff!
Old 03-04-2010   #7
1989ZR1#74
Well I am working on some data/research that shows up until the very last minute, less then a month before the 89 Pilots started rolling off the line the ZR-1s were going to share the 5100001 Vehicle sequence with the L98s. The zr1 would have only been identified by the 1G1YZ and the J for the engine digit. so 5100056 could have been a ZR-1 and 5100057 an L98. I suspect that when they collapsed the LT5 into a ZR-1 only powertrain that the VIN sequence number changed as well.
Until I have more data I can only tell you I think this happened.
Old 05-01-2010   #8
zedrone
The '90 Convertible that I had was a normal VIN number with a J where the engine code went.
Ed
zedrone is offline   Reply With Quote
