Old 03-03-2010   #1
65ZR1
Default Plug wires
I bought a new set of AC Delco wires ( not cylinder numbers) to replace my originals. I took the time to measure each wire to aid in installing the new ones. The problem is, I cant find where I wrote it down. Can anyone measure an original set of wires and tell me how long each wire is and what cylinder it goes to?
Thanks in advance!
65ZR1 is offline   Reply With Quote
Old 03-03-2010   #2
xlr8nflorida
xlr8nflorida's Avatar
Default Re: Plug wires
Use at your own risk but....
From Shortest to Longest
7
6
5
8
3
2
4
1
Provided from ZR1Vette:
drivers side bank from front to rear:
1 3 5 7
passenger side bank from front to rear:
2 4 6 8
Good Luck
Old 03-04-2010   #3
ZR1Vette
ZR1Vette's Avatar
Or just 'connect the numbers'>>
1 3 5 7
2 4 6 8
Michael
:cheers:
[I][SIZE="2"]1990 RED on RED #566[/SIZE][/I]
[I][SIZE="2"]WAZOO MEMBER[/I][/SIZE]
Old 03-04-2010   #4
Aurora40
Aurora40's Avatar
Non-ancient replacements are not numbered.
Bob Saveland
Former owner of #2517
Old 03-04-2010   #5
ZR1Vette
ZR1Vette's Avatar
I know the wires of non OEM are not numbered, but the OEM coils are thus my 'connect the numbers'
Michael
:cheers:
Old 03-04-2010   #6
Aurora40
Aurora40's Avatar
He doesn't know which wire belongs to which cylinder. Or else I'm not understanding what you are saying?
Bob Saveland
Old 03-04-2010   #7
ZR1Vette
ZR1Vette's Avatar
Just slowly relook at my post.. OEM coil pacs with numbers and then what I ID the spark plug sequence per bank. Not trying to make this an issue just making it simple
Michael
:cheers:
Old 03-04-2010   #8
xlr8nflorida
Agreed it works with the information we both provided.
It would be nice to have some NOS numbered coils
Old 03-05-2010   #9
65ZR1
Thanks for the help guys. Listing them from longest to shortest should get the job done. Thanks also for the pictures, I do have a shop manual though. I knew where they went but didnt want to spend a lot of time trying to figure out wich length of wire works best.
Old 03-05-2010   #10
Aurora40
Aurora40's Avatar
Do you mean in addition to the information Xlr8 provided about lengths? If so, I didn't get that part. I thought you were saying that by knowing the coil pack sequence and the engine bank sequence, that he could figure out which wire goes where.
I'm also not trying to make it an issue, just trying to understand what you meant.
Bob Saveland
