Old 02-22-2010   #1
jrd1990zr1
jrd1990zr1's Avatar
Default two unrelated questions
I just took my Z down from the lift and found out the battery didn't have enough juice to start it. Jumped it, started right up. I let it run for awhile to look for a very minor noise from the front of the engine which appears to be the belt tensioner fluttering. I also detect a slight bearing noise. Are tensioners making this type a noise common? I initially thought it might be the alternator but it does not sound like it. Any thoughts?
2nd while the car was running charging the battery I turned the dash lights on to check the charging. I noticed quite a bit of flickering in the interior lights. Does this sound more like a bad battery, or when I pull the plenum should I have the alternator checked out? Any thoughts?
Thanks, John
Old 02-22-2010   #2
tccrab
tccrab's Avatar
Default Re: two unrelated questions
C4's are especially sensitive to low battery voltage.
If your battery is anywhere near it's expected lifetime, change it out.
Clean & wire brush the battery terminals while you're in there.
You shouldn't have any more troubles, but if you do, the next thing is to track down all the engine & chassis ground connections and clean them up.
(you probably won't have to do this, just change the battery).
Idlers make noise as they age/wear. When it gets noisy enough to bother you, change it out. As I recall, the pulley for our ZR1's is a little different than a LT1 or L98 but they still work.
I'll have to dig through the archives, there was a thread about 6 months ago that detailed the differences and also where to buy them without breaking the bank.
Good Luck!
TomC
'Crabs
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 02-22-2010   #3
Jeffvette
I just got done with a car that had a consistent dead battery. It boiled down to somebody leaving a light on and running it down, and it then proceeded to kill the alternator. The alt would not charge a new battery period.
Do not neglect your battery
Old 02-23-2010   #4
Jim Nolan
Years ago I had an '87 that would go through batterys and alternators about once a year. What I found was a bad switch for the passenger side power window up only. Whenever I tried to find a short I usually had the windows down and it would drive me carzy. If the car would sit for 3 or 4 days, dead battery. I only found it by mistake while working on something else.
Good luck!
Old 02-23-2010   #5
Good luck!
If I only had a nickel for every time this happened.
Old 02-23-2010   #6
my 90 had a bearing type noise.. I replaced the pulley on the tensioner, it helped, but noise was still there. i noticed my tensioner was fluttering too, so i replaced it.
this was July 2009, I drove 1400 miles, then had to change the Water pump, due to a leak, found out the noise was the Water pump bearings, on the car i could not tell they were going, once off I could.
then this December i replaced the Alt. bearings were bad on it too. now keep in mind when I got the car in 2007 is was too rough shape and had 60K miles. but it is possible your pump or Alt bearings might be going bad too
Old 02-23-2010   #7
jrd1990zr1
jrd1990zr1's Avatar
Thanks to all for the advice.
The noise is really not that bad, I just am trying to get the car ready for the gathering. Long ride from NY to BG, don't want any problems. I may change out the tensioner, I see one from Partsladi on E-Bay for $149.00. Is this about the right priice for one? They claim they are OEM GM and not reproductions.
I am going to pull the alternator and can have it bench checked, maybe if it is a bearing it will show up. Maybe I should pack a WP for the trip to BG???
New FIC injectors, oil cooler lines and I may try to pull the shroud and see if there is debris in between the radiator and condensor. Any hints on doing that?
Thanks in advance, John
Old 02-23-2010   #8
Aurora40
Aurora40's Avatar
I think a battery charger would be a better way to charge it in the future, vs letting the car run. I believe that can be hard on the alternator.
Bob Saveland
Former owner of #2517
Old 02-23-2010   #9
I got my Tensioner from the Partsladi for that price.. as far as I know it is OEM
Old 02-23-2010   #10
jrd1990zr1
jrd1990zr1's Avatar
I am pretty sure the battery is DOA. It was on a tender, so I need a new one for the BG trip.
I had to move the car to get it over to my 2 post lift so I wanted to run it for a little while. I read it was not a good idea to only run a ZR1 for a short time due to leakage by the valve stems into the crankcase so I let it run about 45 minutes.
My concern was the fluctuation in the interior lights while it was running. I thought maybe I had a bad alternator bearing which was causing the wirling sound and the voltage flutter. I am going to pull it and have it bench tested.
I agree with your comment, it was not my primary intent.
Thanks, John
