02-17-2010 | #1 |
Not another transmission question............
I want to replace the fluid in the transmission and might go with Redline MTL.I spoke with Bill B and I was told this might make the trans a little bit smother.What is the majority using?
02-17-2010 | #2 |
Re: Not another transmission question............
Castrol TWS 10-60 would appear to be the weapon of choice. Down side is it is pricey and only available (mid Atlantic area folks anyway) from BMW dealerships.
Michael :cheers: [I][SIZE="2"]1990 RED on RED #566[/SIZE][/I] [I][SIZE="2"]WAZOO MEMBER[/I][/SIZE] |
02-17-2010 | #3 |
Well this is a first... the BMW dealership charged less per qt. that the internet price
02-17-2010 | #4 |
Cliff, nice link!
Those guys sell it for almost half the price that the local BMW stores sell it for in my neck of the woods. Tom
02-17-2010 | #5 | |
"There is two different colored bottles the Castrol TWS 10W-60 comes in. THEY ARE THE EXACT SAME PRODUCT, JUST DIFFERENT COLORED BOTTLE. The newer bottle, Gold Colored, has updated information on the back which now includes M6 and Z4 M's. Other than that it is the exact same oil… Sometimes the cases purchased from BMW are the new Gold color and sometimes it's the traditional Grey… But not to worry it is the same good 'ol stuff…" Last edited by Dynomite; 02-17-2010 at 08:16 PM. |
02-17-2010 | #6 |
It's odd to me that Bill would endorse RedLine for use in the transmission.
When I acquired my 94 ZR-1, it had about 60,000 miles. While doing all the maintenance, I switched to Red Line in the trans. The original GM fill looked new when drained. In less than 5,000 miles (don't remember the exact numbers) the trans seized, and I mean locked up such that it could not be disengaged by shifting or clutch release. It had to be dragged onto a wrecker. While talking to Bill about a rebuild, he mentioned that he knew of a couple of others that had the same experience with a change to Red Line & was wondering if there was a connection. Enough for me to never use it again. I put Castrol in the new transmission & never looked back.
02-17-2010 | #7 |
I used the Castrol oil from the BMW dealership in my '93 LT1's ZF6 I used to have & never had a problem. I'm planning to use it in my '90 Z's ZF6 also.
[IMG]http://i13.photobucket.com/albums/a292/bdw18_123/_zr1netforumsigphoto.jpg[/IMG][B] 1990 Corvette ZR-1 [/B][I] White/Flame Red, #2299, mostly stock, 144K miles.[/I] -Cams timed to the '93-'95 405HP LT5 stock timing. -IAT sensor relocated to below front bumper. -Haibeck hoops installed in airduct. -OBX cat-back exhaust. [COLOR=DarkRed][B](SOLD - December 2012 [/B][/COLOR][COLOR=DarkRed][B]:hello:)[/B][/COLOR] 1993 Corvette Coupe Black/Black, 6-speed (SOLD - October 2009 :hello:) |
02-17-2010 | #8 |
[QUOTE=Z51JEFF;82404]I want to replace the fluid in the transmission and might go with Redline MTL.QUOTE]
DONT DO REDLINE MTL in the Trans.. It will foam out on a high speed run, and be all over the car not in the tranny. |
02-18-2010 | #9 |
After reading Jerrys response that did it for me,Castrol it is.
