Old 02-13-2010   #1
secondchance
Default LTPWS Receiver
Are all receivers same between 90 to 95?
Old 02-13-2010   #2
Default Re: LTPWS Receiver
Jun,
Here is what I found in parts manual:
10143565 for 90-92 MY
10161858 for 93-95 MY
I also found this old email from list server that might help answer your question:
Subject:LTPWS receiver problemsFrom:Steve Jasik <[log in to unmask]>Reply-To:Steve Jasik <[log in to unmask]>Date:Fri, 5 Oct 2007 15:05:37 -0700Content-Type:text/plainParts/Attachments: text/plain (82 lines)
Stan, Oct 5, 2007I installed the new LTPWS receiver you sent me about 2 weeks ago,and since then I have seen no improvement in the behavior of the LTPWS system.The system continues to display warning lights in an inconsistent fashion.Sometimes the Low tire pressure light comes on within 100 feet offorward motion, way before the car gets up the 27 mph that isnecessary to activate the system. I have interrogated the errors codes in it by grounding terminals A& B of the Diagnostic connector and get different results ondifferent times.If there is anyone at GM who is willing to chat with me, I am open tofurther suggestions, but it is my present opinion that in my caseattempting to fix the LTPWS system on my car has been a total wasteof time and money.Pulling the fuse to deactivate it and the cruise control system wouldhave been simpler :-(Steve JasikPS: Stan, don't take this personally,the problem is GM's failure to adequately test the parts, ...>Steve,> Your order has shipped today(9-7-07) UPS ground.The tracking number>is 1Z1WX6550310072373.The total charge to your card was $178.20.>Thank you for your order.>Stan>Tom Henry Parts>>----- Original Message ----- From: "Steve Jasik" <[log in to unmask]>>To: "Tom Henry Chevrolet Parts Department" <[log in to unmask]>>Sent: Wednesday, August 29, 2007 10:59 AM>Subject: Re: LTPWS questions>>>OK, send me one of the # 88961498 (93 - 96)>>>>send me your phone number and I will give you my CC number.>>>>Steve>>>>>Steve,>>> The GM part number 10143565 has been superceded to part number>>>88960999 and is listed for the 1990-1992 Corvettes.The list price>>>is $244.30 your price is $167.10.>>>The LTPWS module listed for the 1993-1996 Corvette was GM part>>>number 10161858 which has been superceded by GM part number>>>88961498 and is list price $267.86 your price is $160.72. GM has>>>stock on both numbers and the above prices are plus shipping.Hope>>>this helps.>>>Thanks>>>Stan>>>Tom Henry Parts>>>>>>----- Original Message ----- From: "Steve Jasik" <[log in to unmask]>>>>To: "Tom Henry Chevrolet Parts Department" <[log in to unmask]>>>>Sent: Wednesday, August 29, 2007 2:31 AM>>>Subject: Re: LTPWS questions>>>>>>>Stan,>>>>>>>>Can you give me price and availability on the Low Tire pressure>>>>(receiver) module that goes under the dashboard of my 93 ZR-1 .>>>>>>>>I found a part number for it of 10143565 which apparently is no>>>>longer valid according to GM Parts direct.>>>>>>>>I believe you quoted my a price of $160 last summer after I>>>>bought a replacement wheel sensor which didn't solve my problem.>>>>>>>>-->>>>---------------------------------------------------------->>>>Steve Jasik>>>>343 Trenton Way <http://www.jasik.com>>>>>Menlo Park CA 94025 650-322-1386 Voice OnlyProblems? Contact Dave Bright at: [log in to unmask]TOPICS: TECH: or NONTECH:http://www.zr1netregistry.com
Old 02-14-2010   #3
secondchance
Thanks Craig.
It seems MY split is 93. I know Jim's 93 may need one and Phrog had a receiver off a 90 for sale. Ah, well...
Thanks. Hope all's going well!
Old 02-14-2010   #4
Thanks Craig.
Hi Yun,
You're welcome and I understand as Johnny has that one sold and for earlier model. I might have found a source for you and a new one for your MY. About $190 and I'll confirm first and PM you if good just in case you can't find a used one. I'm sure there are some of the recyclers out there that have this and just trying to locate one. I'll keep you posted.
All is going well on this end and thanks for asking. Hope the snow was not so bad in your area. Working on the Z this long weekend and slowing making progress. Can't wait the drive the Beast again.
Old 02-14-2010   #5
secondchance
Hi Yun,
No problem. Jim's 93 seems to have receiver issue. Mine works fine so we will try my wheels on his 93. If the light goes out then we will know it's the receiver for sure. If not, some other issue like wiring.
If only available is $190, prefer to confirm it's the receiver first.
Tanks.
Old 02-16-2010   #6
The short answer is no as the frequency was different from the black to the later White Sensors. So two models numbers as listed above is not surprising.
Old 02-16-2010   #7
secondchance
Thanks for all the help.
