![]() Join Date: Dec 2003
One of our astute forum members noticed that links in threads prior to the switch of this new forum do not work. However he also came up with a cure/fix in the same breath.
Here is the solution; 1) Left click on the referenced link and then just place a period between the zr1 and the net (zr1.net). 2) Then delete registry.com and you are all set. For example....... Before http://www.zr1netregistry.com/forum/...ead.php?t=4101 After http://www.zr1.net/forum/showthread.php?t=4101 ------------------------------------------------------------------ Thanks to Dynomite for the idea, and to WB9MCW for suggesting to make it a sticky for other forum members. JIM ![]() |
![]() Join Date: May 2007
Wow, that's cool! Thanks
Jim |
