Old 02-09-2010   #1
UKZR1
UKZR1's Avatar
Default ZF 6 speed
Does a Lotus Carlton 6 speed ZF box fit a 90 ZR1? Are they the same, ratios etc?
I have a vague idea that something is slightly different but cant remember what an dthat they can be swapped one way but not the other
Red/red 90 #1281 (UK)
Marc Haibeck 368
B&B, Brembos
DRM suspension
Known as 'Gixer' on corvettechat.co.uk
www.corvetteclips.co.uk
UKZR1 is offline   Reply With Quote
Old 02-09-2010   #2
Default Re: ZF 6 speed
I doubt it but give the ZF.doc.com a call or an email
Old 02-09-2010   #3
tccrab
tccrab's Avatar
Looks like transmission is the same, S6-40, but bell housing/clutch is different.
TomC
'Crabs
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 02-10-2010   #4
limey
Totally different. Only thing the same are the gears and counter shaft.
Shift rails - centre and rear case - main shaft - input shaft - sleeve - shifter are all different and you will not be able to use either one in the reverse situation without major mods.
If you have a line on a LC box and it's cheap, BUY IT. They are worth 2-3 times the cost of a ZR-1 LT1 etc box.
If you locate a pressure plate or flywheel for a LC, i will buy it.
limey is offline   Reply With Quote
