What do you have in the works for your Z, or what things would you like to one day do to it? You can also list any fantasy Z's you'd like to have, but I'm more interested in things you reasonably plan on doing.
I'm sure for some of you you've already done these things. I'd like to change my car in the following ways, and these are mostly in order:
![]() What would you like to do to your car? Edit: I also meant more mod stuff than maintenance stuff. But other things I am planning are changing the diff fluid, new tires, and new injectors, in addition to whatever else pops up. ![]() Last edited by Aurora40; 11-17-2005 at 06:01 PM. |
![]() Join Date: Dec 2003
My goal when I started was to be able to reverse any modification to make it bone stock if needed for resale value. So with that in mind I have put on headers, X-pipe, and B & B exhaust, but I have kept the stock manifold/cats and exhaust. I will go with a performance chip once I decide on the best one, and I'd like to get a Dyno Tune from Aaron at SGC. I might go with a P & P of the plenum and IH, but that is about it. If I were to change the rims, I'd keep the stock ones, and if I were to upgrade/change the brakes, I would still be able to reverse them if needed.
So while some of the guys are going for the ultimate in HP ![]() ![]() |
![]() Join Date: Mar 2004
The 93 Green LPE/LSV 385 will stay as it is. And will be enjoyed during good weather. Yes the car gets used in the rain.
The White 91 415 is pretty well done up also. But it may go for sale come spring time. |
Callaway Z Speedster....
For mine: -New leather on the seats -Top end porting job -Headers, bullet cats, Corsas -A Molds -Lowered 1-1/2 in. in rear -Hurst shifter -Paint & tires (done) Good enough for me... |
![]() Join Date: Jul 2005
I consider mine done outside of maintenance items. This winter will be replacing the ZF, water hoses/TS, fluids, plugs, belt and finally more Zaino.
- Headers (CA legal) into RT cats into X pipe into B&B.
- Port & Polish the pleunm and IH. - RC fuel injectors,... and,....... Wait a minute what the hell am I talking about. I just want to fix my GODDAMN vacuum leak!! ![]() Basically I want 400rwhp with a stock look, even under the hood, except for maybe a smooth air intake and slotted/drilled/zinc washed rotors and a caliper that lets go of its heat better than these. I would like to get a fiberglass roof too. |
![]() Join Date: Apr 2004
Just P&P and a good tune Other than that its just how I want it.
![]() Mods so far Open air filter Flowmaster catback tuned chip cross-drilled rotors/GS calipers 5-spokes
Repaint to get rid of orange peel
Port/polish/pc cam covers/plenum redue interior headers/cats/stock 94 system w/flowmasters new tune C6 Z06 Calipers gears (maybe) I like hitting 120 in third bypass the TB coolant line reroute the IAC shifter c-beam plates Keeping it out of the hands of an NCRS guy.......priceless
#9 | |
#10 |
I think I'm done with this one. Planning for the next one, though!
