Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 ZR-1 Prototypes (pre-production)
Old 01-25-2010   #1
1989ZR1#74
Default 1989 ZR-1 Pilot #004 Thread
I thought I would start a new thread covering the status, update, and documenting of 89 #004. For information on the auction or previous found data click here:
http://www.zr1.net/forum/showthread.php?t=10927
Lots of updates today. Put a new battery in, out the passenger tire back on. Replaced the driverside tire with the a 91 rim that came with #74. Still need to resolve the flat gator back.
First things first. Found a partial stamping on the oil pan boss when changing the tire:
When I connected the battery she started showing signs of life:
But I now know why the Odometer is under reporting the miles...
Not sure maybe the 8000RPM dash wasn't ready yet, but I doubt that.
Eric
1989ZR1#74 is offline   Reply With Quote
Old 01-25-2010   #2
1989ZR1#74
Default Re: 1989 ZR-1 Pilot #004 Thread
LT-5 from passenger side:
LT-5 from drivers side:
Old 01-25-2010   #3
1989ZR1#74
Restoring some dignity to the old girl:
Driverside with 91 wheel
Lights work.. (most of them anyway)
Old 01-25-2010   #4
DMark
DMark's Avatar
TAG!
DMark is offline   Reply With Quote
Old 01-25-2010   #5
Jeffvette
Sucks on the cluster. There was a guy selling one for about 5k a couple of years ago.
Like seeing the progress pics. Extremely cool.
Old 01-25-2010   #6
1989ZR1#74
Electrical Systems check on battery install:
1. Wipers work all settings
2. Both power windows roll up and down
3. Door chime works
4. Door ajdar works.
5. Radio works, but not through all speakers.
6. Power antenna works.
7. Dome/courtesy lights work and time off delay works.
8. Headlights work, drivers side amber light doesn't.
9. Power mirrors work. both drivers and passenger side
10. Dash information functions for Trip odo and Volts.
11. Dash information displays "Err" on Oil Pressure, Coolant Temp, Range, Instant MPG.
Old 01-25-2010   #7
scholtmj
scholtmj's Avatar
Cool looking PCV and TB coolant lines!
Old 01-25-2010   #8
Jeffvette
Eric, I'll look and see if I can find the ad.
You were in the post..... http://forums.*************.com/c4-p...-rpm-tach.html
Old 01-25-2010   #9
1989ZR1#74
That's the cluster out of #75. I traded emails with the guy back when he had it up on ebay and forsale on cf. Was selling the console armrest with SPI as well. #75 is reported by carfax as destroyed at a salvage yard in MI.
I need to find out if the 8K was in the pilot. There is a ton of things different between #004 and #074 so I am hoping!.
Old 01-25-2010   #10
1989ZR1#74
Front tires/wheel dates
Passenger Tire Date: 028 2nd Week (January) of 1988
Passenger Wheel Date: 02/29/88 Leap Year!
Drivers Tire Date: 098 9th Week (February) of 1988
Drivers Wheel Date: 01/29/88
These match with the assumption that this ZR-1 was assembled in 3/88
