01-03-2010 | #1 |
AntiFreeze
If you are running 50/50 mix, what is the protection level?
I'm getting +5 degrees on my 93 LT1. Does that sound right? I'm thinking it should be -30 or so. Last edited by xlr8nflorida; 01-03-2010 at 12:20 AM. |
01-03-2010 | #2 | |
Re: AntiFreeze
5 deg should be fine for you and definitely more protection level than you need. You would prolly use antifreeze more for rust protection than for freezing protection Last edited by Dynomite; 01-03-2010 at 12:42 AM. |
01-03-2010 | #3 | |
Re: AntiFreeze
I'm just wondering if the antifreeze lost some of its Zing. I'm thinking its time to change it anyway and give it some fresh mix. |
01-03-2010 | #4 | |
Re: AntiFreeze
http://www.zr1netregistry.com/forum/...+refill+method http://www.zr1netregistry.com/forum/...ead.php?t=3213 http://www.zr1netregistry.com/forum/...ad.php?t=10777 Last edited by Dynomite; 01-03-2010 at 12:55 AM. |
01-03-2010 | #5 | |
Re: AntiFreeze
Thanks, I now have a headache Can someone give me the cliffs of the acceptable antifreeze? For example, I can go to NAPA and get the green stuff, what is the part # and I need 2 jugs right? |
01-03-2010 | #6 |
Re: AntiFreeze
You need to check specific gravity of coolant using an inexpensive Floating Ball Tester (Hydrometer) you can get at any auto parts store. You suck up some coolant (cold) directly from radiator or coolant overflow system into the clear tube and observe the number of floating balls to determine the degree of protection. The accuracy is within 8 to 10 deg.
01-03-2010 | #7 |
Re: AntiFreeze
Jim,
sorry to be blunt, but toss the coolant. It's shot if you are sure that you did a 50/50 mix the last time it was changed out! Unless you were adding along the way using just water and not a 50/50 mix for top off's? You do have a fav local chevy store that you use regularly for parts? Get them to order the GM stuff, 4 gallons per case, they should be okay with a one case order. You will have enough stock to do two flush & refills which will get you 4 yrs down the road. GM p/n = 12378560 Sorry I can't help with the NAPA p/n's. Tom
01-03-2010 | #8 |
Re: AntiFreeze
I don't have a part number, but the labeling identifies the 1825M spec and also specifies there are silicates in the antifreeze. It's a NAPA brand and they usually have jugs of it available. Mine is in a blue jug.
[I][FONT=Comic Sans MS]John Boyd[/FONT][/I] [I][FONT=Comic Sans MS][SIZE=1]Ideho[/SIZE][/FONT][/I] [FONT=Comic Sans MS][SIZE=1][I]2015 ZL1 [/I][I]Camaro #1121 BLACK/BLACK 6 SPD (540 RWHP)[/I][/SIZE][/FONT] [I][FONT=Comic Sans MS][SIZE=1]1991 ZR-1 #458 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK 72[/COLOR]k miles ([B][COLOR=red]SOLD[/COLOR][/B]) 1991 ZR-1 #473 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK [/COLOR]37k miles ([B][COLOR=red]SOLD[/COLOR][/B])[/SIZE][/FONT][/I] |
01-03-2010 | #9 |
Re: AntiFreeze
01-03-2010 | #10 |
Re: AntiFreeze
