![]() Join Date: Feb 2009
While performing some under hood cleaning I bumped the wire going to my master cylinder it broke at the connector. Can these connectors be obtained at any auto parts store or is there a better source?
Rich
![]() Join Date: Jul 2005
I believe that's used on every C4 since 89. Shouldn't be too hard to find. I suspect you'll be getting one from a salvage dealer because it's part of the harness.
![]() 1991 Chevrolet Corvette ZR-1 |
![]() Join Date: May 2007
Rich,
You may be able to put a new metal female connector on the end of the existing wire and the insert it into the plastic portion of the connector. Check out this thread concerning the Oil Pressure Sensor connector repair: http://www.zr1netregistry.com/forum/...ead.php?t=8985 Try this site, Repair Connectors Store: http://www.repairconnector.com/ I haven't bought the Mastercylinder connector specifically from them but they may have it. I have the tools and I might have a spare connector if you need to repalce it. Jim |
#4 | |
Here's the site: http://www.electerm.com/packard.html Rich
1990 Bright Red Coupe #608 380 Stroker, Ported Heads/Intake/Housings/TB Haibeck Secondary Delete Chip / Pete's Cams George Braml Intake / FIC Injectors Coated SW Headers / Corsa Bill Boudreau B/B ZF6 / Viper 4.10 gears Ron Davis Radiator Pioneer AVIC-Z140BH NAV Fikse FM5's 285 / 335 / C6 Brakes WAZOO Member Last edited by Scrrem; 12-29-2009 at 11:29 AM. |
![]() Join Date: Aug 2006
I bought one from GM a couple years for my 90. Was off & melted when I got the car
