What brand are you using??? Going to change mine soon,any tip or tricks I should know about?
#2 | |
![]() Join Date: Dec 2003
http://www.zr1netregistry.com/forum/showthread.php?t=994 Different people have their own preferences just like with motor oil. Regardless of what brand you use, you want to only use distilled water with it. This will help to keep the mineral deposits/scale etc., to a minimum. Depending how cold it gets in your part of Utah, you may also want to go the route that some do and only use distilled water along with Redline Water Wetter. It provides rust and corrosion protection along with lowering the temperature. However, it is not an anti-freeze, so if it gets cold where you live, you will also need some anti-freeze with it. More on Water Wetter in this thread; http://www.zr1netregistry.com/forum/showthread.php?p=4182#post4182 Good luck and let us know what you decide to do. ![]() |
![]() Join Date: Nov 2005
Texaco Dex-Cool. Change your thermostat also. You do not want to get these engines hot!
I'm using that Prestone Extended-Life All Model stuff. It's basically Dex-Cool but yellow. I couldn't find silicated coolant locally. I think I will try G-05 or whatever the Zerex stuff is called, though.
I'm not a fan of flushing coolant systems unless there's crud in them. Pumping water through that isn't distilled seems like a good way to introduce crud into what was a clean system. |
#5 | |
![]() Join Date: Dec 2005
Good luck..maybe someone else can comment about the entrapped air?? |
in the members newsletter Marc H. tells the whole story on the coolent debacle air entrapment...3 of ten have the air trap most will self bleed out and for the final 10%(one) he has devised a posi psi pusher thru and out the air bleeder spot device that is all detailed well in his article...pays to be a member (pun intended= am ex ad) lol.... My mech said he goes with the Prestone.
![]() Join Date: Dec 2004
If one was to go look at CF/ZR-1 section there is another thread up on this subject. If I'm outta line by bringing up the reference to CF, I'm sorry.
Anyway, MrCrowley presents some evidence of the damage that DEX-Cool the red stuff did to gaskets in an LT5. I've tried to find "silicated" coolant where I live & most parts stores don't have it. I went to my local chevy store & asked for the stuff listed in my 90 owner's manual by GM spec #, 1825-M, they said NLA on that stuff. Further they said that the stuff in the C5/C6's is what replaces the 1825-M coolant. The concensus over at CF by the Z owners is not to use the DEX Cool red coolant in an LT5. I don't know what to say as I'm not a chemist. A few owners that live in Canada have found the "silicated" stuff & are stocking up. I let the dealer do my flush & refill but now I'm on a search for the "silicated" coolant based upon what is being said over at CF/ZR-1 section. Tom ![]()
DEX COOL
#9 |
I have seen the light!! I thought I had researched and found that Dex cool was the cats meoww. After reading the posts here nd at CF, I am getting this crap outta my Z. I'm going to put regular Prestone in for now. Tell me, What should I use. I have found on the Prestone site, a coolant that might be OK, but you guys are the experts. What should I use?
I found that Zerex G-05 has silicate. I will be using this until you all convince me of something better. Last edited by cwmoss; 12-17-2005 at 02:34 PM. |
#10 |
Prestone's All-Model extended life coolant is basically the same as their Dex-Cool approved coolant.
There is a coolant called G-05 that Zerex came out with, it's a hybrid OAT with a low amount of silicates. It seems interesting. Otherwise, just go with silicated green coolant. http://www.valvoline.com/pages/produ...asp?product=10 |
