Old 12-17-2009   #1
secondchance
Default Seat Control Trim Plates
These trim gets stained and sad looking after 15 plus years in the car.
Easiest way to clean this up is to get a raser blade to pick up one corner and pull up the trim plates (very carefully as not to rip or bend). For seat control, fore and aft, you need to protect the plastic trim, slide a screw driver blade under the sliding switch and pop the piece out.
After trim plate has been removed, wet sand it down with 800 grit followed by thin layers of satin clear spray paint.
I used Pactra plastic model sparay paint.
http://i658.photobucket.com/albums/u...91213-0959.jpg
When fully dry, used double sided scotch tape to re-stick over the control switch assembly.
Old 12-17-2009   #2
secondchance
Default Re: Seat Control Trim Plates
Oh! This one is for you David.
Old 12-17-2009   #3
4DSZR1
4DSZR1's Avatar
COOL idea!
4DSZR1 is offline   Reply With Quote
Old 12-17-2009   #4
Scrrem
Scrrem's Avatar
Pretty slick idea
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 12-19-2009   #5
secondchance
If any of WAZOO guys need this done, let me know.
I will bring the spray and double stick tape for the next gathering.
Merry Christmas!
Old 12-20-2009   #6
Thanks for taking the time to share this great tip; mine is in need of some detailing like this.
Old 12-20-2009   #7
secondchance
I have 14 years combined Z ownership between 91 and current 94.
Although I insist on driving it everyday and high mileage doesn't bother me. But cosmetically looking new is important to me. When parts started to disappear at the dealership, especially interior trims, I had to resort to all my early experiences (like building Revell kits).
One last tip - after refinishing, use black permanent marker and carefully go over side edges. This will make it look much neater once attached back on the switch.
Old 12-20-2009   #8
Thanks again, the detailing tips are invaluable as you said since many parts are no longer available. By the way, I will be staying at the Hilton in Springfield, VA when I visit the D.C. area next month. I'll reconnect with the details and schedule to see if a meeting is still possible. I need to start digging out the winter clothes I see.
Old 12-20-2009   #9
secondchance
We'll be here.
