![]() Join Date: May 2008
I have a broken bracket . Can any one tell me is there two parts.
One that mounts the brake booster then one to hold the ecm itself. The one on ebay or even the catalogs I would guess shows the bracket that mounts to the booster right. Were would I go to find the one for holding the ecm itself. Any help guys would much appreciated . ![]() Russell 91 Polo Green #1501 |
![]() Join Date: Jul 2004
There is the little finger that pokes away from the brake booster that is what I call the ECM bracket, It is just behind the booster and is held with the studs off the booster, the booster must be removed to replace this.
Then there is the plastic retainer that the ECM lays in this slides onto the bracket and that's what holds it in place, the ECM then lays down on that and has the 2 nuts securing it to the retainer. What one did you break? The plastic part is available but the pot metal bracket that sits behind the booster is ZR-1 specific and I have a spare if you need one just let me know. I also have the plastic one.. ![]()
JOHNNY P Currently own 90 ZR-1 #845 DRM 500 engine package 90 #226 Parts car Hit me up if you need anything. Last edited by phrogs; 12-12-2009 at 11:35 AM. |
broke the one that holds the ECM itself.
What broke is the part that connects the hood pin channel. |
I bought a new one from Arts Corvette Parts about a year ago,I think it was maybe $20.This is the plastic part that the ECM sits in.The part # is 10086259.
