![]() Join Date: Feb 2009
Does anyone have a vendor who makes a direct replacement braided clutch line for the ZR-1? My OEM stock line has some corrosion and when I change my clutch, I would like to replace the line as well.
thanks Rich
Were you intested in upgraded to the 91-96 part number: 12509314 (this one is braided)? I recently did that to mine per recommendation of ZF Doc and changed to the later model slave too. Sorry, maybe I misunderstood what you are looking for.
#3 | |
![]() Thanks Rich
![]() Join Date: Dec 2004
If you use the OEM 90 slave cylinder, the 91 & up replacement line should fit. You may have to re-bend some of the pre-made bends....I'm not sure, sorry.
I know that when I changed out my 90 OEM slave for the replacement 91 & up slave, my 90 OEM line would not quite make the right bends down at the newer slave. I was lazy and had the newer line but was in a hurry & didn't put it in at the same time. I had to re-bend the last little bit of the old line to get it to fit. ![]() Judging from my foray I would guess that we should do the 91 & up line + 91 & up slave cyls together? ![]() Tom
http://www.zfdoc.com/clutch_hydraulic.htm
Hi Rich, All I know is I was consulting with Bill Boudreau when I was doing it all and he told me he highly recommended upgrading to the later style for various reasons so I did. Sorry, I can't answer your questions but mostly likely true like Tom experienced. Shoot Bill B an email just to be sure. He is awesome and always willing to help. I know it could cost a little to do so though....especially during the holidays. ![]() |
#6 | |
Rich
![]() Join Date: Mar 2007
#8 | |
![]() Rich
#9 |
$85 plus shipping.....they can be alittle slow if they are busy.
these are made in the USA
