Old 12-07-2009   #1
max76
Default Remove door panel
Hello guys, i want remove the door panel to change the Anti-Rattle Door Window Bumper...Someone of you try to remove the panel?
May you put a little description??
I have some trouble with the look/unlook part.How i can remove it???
Thanks in advance
Max
max76 is offline   Reply With Quote
Old 12-07-2009   #2
bdw18_123
Default Re: Remove door panel
The lock-unlock slider can be a little difficult to remove. It needs to be in the "unlocked" position, then you need to carefully pry the "knob" part out away from the door. The plastic lock slider snaps into a metal rod that is behind the plastic part.
Here are some pictures of the driver's door on my '90 Z that might help:
To remove the lock-unlock slider, position a flat blade screwdriver as shown and carefully pry out on the plastic piece:
Lock-unlock slider removed:
Then, proceed to remove all the door panel screws to get the door panel off. One is here behind the latch to open the door:
There is one hiding behind the lock-unlock slider. There are also 1 or 2 more screws behind the light above the handle to open the door. The light has to be carefully pried out (it has tabs that snap in) to gain access to these screws. You can then remove the plastic bezel behind the door open handle, unplug the door light:
Old 12-07-2009   #3
bdw18_123
Two in the door pull cup, then remove entire door pull assembly with switches and unplug the switches:
One at the back end of the door above the hatch release switch (don't forget to unplug this switch when you go to pull the door panel off):
One at the forward part of the door:
And finally, the row of screws at the bottom of the door in the carpeted area. Door panel should now be able to be lifted up then out:
Passenger door is similar.
Old 12-07-2009   #4
Jeffvette
Except you have to remove the window switch button on the passenger side to get on last screw/bolt.
Old 12-07-2009   #5
Correct its deep inside underneath the power window switch on the passenger side. And there are screws behind the light in the door if I remember
Old 12-07-2009   #6
bdw18_123
Oh, yeah, forgot about that one! Now that I think about it, you guys are probably right. There might be some behind the light in the door, too. The light has to be pried out, it snaps in with tabs.
Old 12-08-2009   #7
max76
Thank you so much bdw18_123 these are precious informations for all the corvette entusiast!!!!
I post this link in my forum club!!!
Thanks to all as every time
Old 12-08-2009   #8
Is the door panel removal (drivers and passengers) on the 91 Z identical?
Great information...thanks
And....Jeffvette....I am assuming your Interior Project is a 90 Z? If so.....is that similar for a 91 Z?
Old 12-08-2009   #9
Yes %100 the same
