Old 12-05-2009   #1
detch
detch's Avatar
Default Lumbar pump question
my lumbar pump starts to run but slowly dies out with in a few seconds and not filling the bladders, any ideas befor I pull it apart?
thanks
Mike
detch is offline   Reply With Quote
Old 12-05-2009   #2
Default Re: Lumbar pump question
thanks
Mike
Could be the switch, I had an issue like that with a switch
Old 12-06-2009   #3
besides not filling the bladders my passenger seat pump was doing something similar, started out strong but would slow way down as it ran, not stopping completely though.
Anyway, when I took it apart I found that the rubber torn in several places and it was winding up around the motor shaft(?), where the screw holds the rubber to the drive. It's like a crank type of set up and one of the fragments was winding around the drive & stopping the motor.
The rubber dish washing trick over at the Reg site did the trick!
Old 12-06-2009   #4
Or got to a Local bicycle shop and get an old inner tube, that is what I used
Old 12-06-2009   #5
ZR1Vette
ZR1Vette's Avatar
As stated already could be the membrane jamming up things or it also could be a bad electric pump motor...after running a bit 'bearings' start to lock up or armature overheats.
In my case it was the membrane bunging things up (Membrane detached from Plunger) >>>
All the pieces from the membrane>>
Once you get apart here are your basic components>>>>
If it is a membrane issue then you can repair>>
If it is the motor unit... well then you will be getting a replacement pump which runs about $150 new (the OEM manufacturer no longer makes the lumbar pumps)
Michael
:cheers:
[I][SIZE="2"]1990 RED on RED #566[/SIZE][/I]
[I][SIZE="2"]WAZOO MEMBER[/I][/SIZE]
Old 12-07-2009   #6
detch
detch's Avatar
Thanks,
I got my project for this weekend.
Mike
