Old 12-03-2009   #1
Scrrem
Scrrem's Avatar
Default 30MM Sway Bars w/ FX3
I have recently been researching my suspension and found that because I have FX3, I don't have the sway bars my build sheet says I should have. Has anyone with FX3 upgraded from 26MM to 30MM front sway bars? If so, has it affected or dimished the performance of the FX3 at all?
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 12-03-2009   #2
Hammer
Hammer's Avatar
Talking Re: 30MM Sway Bars w/ FX3
Rich
I just put a 32 mm on. I'l have to try the suspension settings next time I drive it. I'll get back to you once I do. Where did you find that info? I'd like to look at it.
Old 12-04-2009   #3
Scrrem
Scrrem's Avatar
Default Re: 30MM Sway Bars w/ FX3
John,
I found this info on another forum, but I believe it has been discussed on this forum as well. The post stated that even though your build sheet says ZR-1 and Z51, if the car was ordered with FX3 ride control, you got downgraded to stock springs and sway bars. After looking at mine, that is in fact the case. I have 26MM front sway bars and stock springs (they are maked with a code). I'll look for the article and post here.
Rich
Ron Davis Radiator
Old 12-04-2009   #4
Ccmano
Ccmano's Avatar
I've run a 32mm front bar for 2 yrs now. It has minumal effect on the on the ride. The FX3 works the same. Cornering however is flatter than ever if you can imagine that. It does introduce a small amount more of understeer, which allows you to compensate with the throttle. I like it very much. The whole theory of sway bars is to improve handling without adversely affecting ride.
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 12-07-2009   #5
Scrrem
Scrrem's Avatar
Here's the discussion on suspension from the other forum (CF).
http://*******.com/c4-tech-performan...es-please.html
Rich
Ron Davis Radiator
