Old 11-27-2009   #1
Jagdpanzer
Jagdpanzer's Avatar
Default Stud Kit for Cylinder Heads and Main Bearing Caps
I work for a German engine company and can get about any metric fastener that exits, either off the shelve or special made. I would like to look into putting together a stud kit to replace all of the cylinder head and main bearing cap bolts on both two bolt and four bolt blocks. Can someone knowledgeable provide the necessary specs:
  • Fastener size,
  • Stud length
  • Thread pitch
  • Threaded length
  • Strength grade
  • Any other important info
Old 11-27-2009   #2
Polo-1
Default Re: Stud Kit for Cylinder Heads and Main Bearing Caps
Ron Woods has the head studs from ARP.
I can get the 2 bolt main measurement's on Monday. I can tell you ARP wants over $178 per stud not including the nut and washer. When I told them to build me 3 sets, never heard from them again.
Old 11-27-2009   #3
Jagdpanzer
Jagdpanzer's Avatar
Any idea what the ARP head studs measure?
Old 11-28-2009   #4
Jagdpanzer
Jagdpanzer's Avatar
Had a dream last night that I started work on the mother of all LT5 big bore strokers
Old 11-28-2009   #5
Had a dream last night that I started work on a big bore LT5 stroker
I almost fell off my chair........good one.
Old 12-01-2009   #6
Polo-1
Here is what I have......
For 2 bolt blocks.
Old 12-01-2009   #7
Jagdpanzer
Jagdpanzer's Avatar
Thanks Kevin, thats what I needed.
