Old 11-25-2009   #1
jeasen
Default 1994 Mufflers
I want to upgrade the exhaust on my 1994 ZR1. My first thought was Corsa, but after reading a report on the 1994 exhaust system by Haibeck Automotive it appears that the bottle neck in the 1994 factory exhaust is the mufflers. Only 1 psi difference across the cats, no difference in pressure across the resonator, but 4 psi increase in front of the mufflers. A Corsa system would not do anything for the difference in pressure across the cats, and there is nothing wrong with the resonator. So maybe just a muffler change??
Anyone know of a non restrictive replacement muffler for the 1994 ZR1? It appears the the diameter of the pipes leading to the factory muffler is 2 3/4". The LT1 mufflers are 2 1/2" or 2 1/4" and would be no improvement over the stock ZR1 mufflers.
There is nothing wrong with my exhaust system I just want to add a little more performance.
I guess I could just remove the mufflers and replace them with a straight pipe but I am concerned about the noise that would make?
Anyone have any suggestions or thoughts on this?
1994 ZR1 Red on Red #111
jeasen is offline   Reply With Quote
Old 11-25-2009   #2
jonszr1
jonszr1's Avatar
Default Re: 1994 Mufflers
you might go look on the corvette action center , and see what hib halverson put on for mufflers. i believe they were 3 chamber flowmasters
Old 11-25-2009   #3
Kb7tif
Headers. You will like them. A bit loud though.
1995 Convertible Supercharged Auto
1974 454 550hp (avatar car) On the blocks- -Scharger install !
1992-Zr-1 Sold.
Watson Headers
Ported Plenum, Housings
Random tech cats
Fidanza Flywheel
Chipped, Relocated Mat
Woods 165 stat
Borlas, Straights
1996 Lt4 Sold
1994 Lt1 Sold
2004 Z06 Sold
AKA** Illenema
Kb7tif is offline   Reply With Quote
Old 11-25-2009   #4
secondchance
I don't know whether it's the muffler design or the pinching of pipe as it connects to the factory muffler.
I personally like the 92 and later factory muffler tips. I think Corvette Central carries Magnaflow mufflers and it looks like it retains factory style tips (a wide black rectangular tip).
Does anyone had experience with Mangaflo?
Old 11-25-2009   #5
Negative.... That is the sound that an LT5 should sound like!
Old 11-25-2009   #6
1990 415
Definitely go with headers and straight pipe. I have this on both of my ZR-1s and it sounds awesome. Straight pipe gives the sound of a serious performance sports car.
1990 415 is offline   Reply With Quote
Old 11-25-2009   #7
902066
Lets here a sound clipp of one of your cars, for those of us thinking of going this route. Please
902066 is offline   Reply With Quote
Old 11-25-2009   #8
Jeffvette
You'll have to show up at BG, he is internet impaired.
Old 11-25-2009   #9
32valvZ
32valvZ's Avatar
You will never notice a performance difference by changing mufflers on any car. Sound difference, yes, but not a noticeable SOTP feel. Listen to us and bolt on some headers and then a nice Corsa or B&B cat back system. Youll have performance along with the sound improvment.
[B]1990 #2815[/B]
Ported Plenum & IH (by Pete)
Haibeck Chip
Rebuilt FPR (by Phil)
FIC Injectors
Watson LT Headers
3" Stainless Works exhaust
Lingenfelter Open Air Lid
Bill B Built Transmission
Shifter & C Beam Plates
[B]SOLD[/B]
Old 11-26-2009   #10
1990 415
I take that personally - even if it is true
I will have my 415 with straight pipes at BG in May. I'll be glad to give you an earfull. I detest mufflers on a ZR-1.
