Old 11-23-2009   #1
Stan Masta
Default Tachometer reads too high
Anybody knows where the problem lies? GM manual suggests bad ground or open in the DIM circuit.
Stan Masta is offline   Reply With Quote
Old 11-23-2009   #2
limey
Default Re: Tachometer reads too high
If it's reading 1000 RPM's higher, that's pretty typical for a 1990 Model, which i presume you own as these are prone to this issue.
Only fix is to replace the Tach in the cluster.
limey is offline   Reply With Quote
Old 11-30-2009   #3
rhipsher
rhipsher's Avatar
Is it just reading high and idling normal?
