11-17-2009 | #1 |
Coilover Spring rates
So I did the Coilovers on the front of my car in June of this year. When I installed them I did 425# springs
I am getting ready to order the rest of my parts for the rear conversion, but what is a good spring rate?? I was thinking of 300# or 275# but what is the benefit of either?
11-18-2009 | #2 |
Re: Coilover Spring rates
I would like to know as well.
11-18-2009 | #3 |
According to Doug Rippie, 300# will be too stiff and he recommends 275#
they use 450# or 400# for the front, I am running 425# and like that so far Coilovers for the rear got moved to the backburner again due to other issues that have come up
11-18-2009 | #4 | |
Thanks for the research I remember Ron talking about the buckboard rear springs he had setup so I was wondering
11-18-2009 | #5 | |
I've never installed them though, so I don't know. Looking at the leafspring rates, 300 is less than the Z51 rear rates, and above the base rate. 425 front is more like the '92+ cars that had softened front spring rates (even the Z07/Z51 cars). I don't want softer fronts, so if I ever did install them I'd go much stiffer front like 5-600. Did you have to relocate the sway bar to do the fronts?
11-18-2009 | #6 | |
rear is still OEM and since I still have time I need to thin about the 275 vs 300 a little more. For me with the leafs or the front coils I drive in sport mostly
11-18-2009 | #7 | |
A stock '90 ZR-1 has a 96.2 N/mm spring, which is ~550 lbs/in. The Z51 rate was 660 lbs/in. The '92+ Z was 430 lbs/in. So I'd think a 425 coil spring would be softer than the later cars. People who install coil-overs though do not seem to go to those sort of extreme rates in the 550+ range. Which is why it seems like the math must be more complex than that or something?
11-18-2009 | #8 | |
I will see if I can find it again
11-18-2009 | #9 | |
Post by Glass Slipper on CF in this Thread http://forums.*************.com/c4-z...g-the-fx3.html
The quote refers to rkreigh who is using 400 front/ 250 rear according to the link above Quote:
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - Flowmaster Cats - Borla Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 Last edited by -=Jeff=-; 11-18-2009 at 11:23 PM. |
11-18-2009 | #10 |
