Old 11-16-2009   #1
1963korvette
Default Vacuum pump not coming on?
Bought car 3 months ago. It has been running very rough. Idle seems high at about 2000 rpm's. bogs down thru 3000 to 5000 rpm's. Tested the vacuum pump testerday. Turned on ignition key and did not hear pump come on. Don't know where to go from here. Appreciate any help or ideas.
1963korvette is offline   Reply With Quote
Old 11-16-2009   #2
QB93Z
QB93Z's Avatar
Default Re: Vacuum pump not coming on?
You have done valuable troubleshooting already. 2000 rpm idle probably means an air leak in one of the vacuum lines attached to the plenum.
The bogging in the 3000 to 5000 rpm may be due to the seconday system being commanded on and then commanded off again when the vacuum switch senses that the secondaries did not open.
Try running the car with the Power Key off. If the bogging down goes away you have confirmed that problem is the secondaries.
My 1994 ZR-1 had similar problems after I bought it last May. The vacuum pump was seized and rusted, probably from running all the time trying to keep up with a vacuum leak. In my case it was a failed check valve in the secondary vacuum system.
You may have a disconnected vacuum line, 2000 rpm idle is a large air source to the plenum.
Check the Manifold Air Pressure Sensor (back of the plenum) hose and make sure it is connected to the plenum. It is under the MAP sensor.
It is possible to test the vacuum pump using jumper wires from a 12 volt source connected to the terminals, but I would guess 95% probability that the pump is bad. I haven't checked on the availability of the 1990 style vacuum pumps lately but there have been some recent posts about replacing the pump using the later model pump by changing the connector.
Have you ever pulled the plenum on an LT5?
If you need help, I might be able to find someone near you that can assist.
TomTom are you listening?
Good luck,
1990 Black ZR-1 - sold
1993 Quasar Blue ZR-1
1994 Competition Yellow ZR-1
1995 Dark Purple ZR-1
Maryland State Coordinator
Old 11-16-2009   #3
secondchance
Good luck,
Well said!
Only exception possibly is my personal experience with blown vacuum to MAP resulted in the motor huffing and puffing and barely could hold idle.
secondchance is online now   Reply With Quote
Old 11-17-2009   #4
tccrab
tccrab's Avatar
First things first, find the vacuum leak.
You've got a big one.
The vacuum pump only assists the secondary system when the engine is at high rpms for an extended time.
Don't worry about him right now, but know that you'll have to come back to him later.
First thing is to check the MAP sensor hose.
It's behind the plenum on the drivers side.
Use a flashlight and look for a pipe that is disconnected.
It's a common thing, this hose pops off when the engine backfires during a startup when the key is not held in the start position until the engine is running.
The LT5 takes longer to start than a regular Chevy engine for a couple of reasons, but primarily it's because there's no distributor. All the sensors have to polled by the ECM before the actual signal to fire the coils is sent.
Here's all you need to know about your secondary system:
http://www.corvetteactioncenter.com/...diagnosis.html
After you get your leak fixed, then it's time to work on the vacuum pump.
Let us know when you get there. There are a few options.
TomC
"Crabs"
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 11-17-2009   #5
1963korvette
Thanks for the replys guys. When I first noticed the bogging it seemed to be only with full power. However, now it feels the same either way.
Old 11-17-2009   #6
Reporting as ordered, Sir!
Have tools & will travel........Road Trip! NJ, what exit??? Now I really have to go get another EZ-pass module for the Z!
'63 PM me if you need help. Or thomastom72@aol.com is my e-mail addy. I have a scanner & software for a 90, plus a ton of spare parts.
As others have said, vacuum leak(s) will give an alternate air route to cause a higher idle. Or, the MAP hose is blown off, I'd check that first as it's the easiest thing to check. If MAP is okay, then start looking at all the vacuum lines after plugging the hose from the pump that goes under the plenum. You could throw a mity-vac pump on that one to check if the under plenum stuff is okay. Also, on a 90, the fuse for the pump is over on the driver's side bolted to the rear inner wheel house panel. It's a small rectangle usually near the s/s brake lines. That fuse could be blown, probe the connector @ the pump for 12v w/KOEO & see what's up.
Bogging, does it knock when bogging? Could be a lean bog, bad injectors or a big vac leak? At idle, no missing, right? You checked for good spark? Condition of the plugs, PCV's, Fuel filter are all okay? Or, do you mean "it's breaking up" or "chugging" when you put your foot into it? Bad MAP or disconned MAP hose.
I will check my software to see what yrs are covered, I have a 90 so that's where I stopped reading.
Old 11-17-2009   #7
1963korvette
Wow that a lot of questions. Will check out all these possible problems when i get home tonight. The best way to discribe the bog is it feels like its getting to rich a mixture and engine is flooding. If I need help I just might take you up on offer to come on down. 30 sec. off parkway exit 166.
Thanks
Rich
Old 11-17-2009   #8
Hi Rich & welcome to the Brotherhood!
Okay, not a problem....we're like that in this group. I have software to 93 on primary cartridges and a troubleshooter up to 92 for my scanner.
I would say that from your further description to check that MAP hose. Also, check to see that hose is not full of oil, that happens alot and it can cause the MAP to not get the vacuum input as it clogs the MAP over time. Can you smell it at idle if you give a sniff at the tail pipes? At speed can you smell it in the car?
Old 11-18-2009   #9
1963korvette
Ok, here we go. Got home last night, unfortunately it was dark, the 63 hogs the garage. Inspected the engine for any loose hoses and wouldn't you know found one. It sits behind the engine just under the pellum behind the distributor about a 3/8 inside dia. hose about 8 inches long. But whats puzzling is what it looks to go to I would have to bend it like a pretzil to get it on. The piece it seems to go to has two nipples coming out, obviously one is open. Started engine and could have vacummed my house with it. When I put finger over the hose my idile dropped down immediately. Have attached photo of where it comes from to kinda where it goes.
thanks
Old 11-18-2009   #10
I have to get me some of that Ginko stuff, forgot to add that I have a spare vacuum pump in my parts inventory........justthat it's the one from the truck catalog and we will have to adapt the wiring at the connector. I may also be able to restore your pump. I did mine. It took some time and some solder and contact cleaner...a lot of busy work, but they are repairable.
Okay I looked & that is the PCV system. We have two valves. As long as the rubber is intact and the PCV's rattle when you shake them, then you should be okay. If you find any suspect rubber parts let me know as I have a good inventory of all that stuff!
