Go Back   ZR-1 Net Registry Forums > Club Regional Areas > Mid-Atlantic Region
Old 11-07-2009   #1
Aurora40
Aurora40's Avatar
Default Final drag racing of the season
Me and a friend will be heading to Mason Dixon today, as we realized this is the 2nd to last test and tune. Short notice, so I don't expect anyone to come along.
But their final T&T date is Nov 22. We're gonna try to hit that date too, assuming the weather is nice.
Anyone else wanna come along? Should be some nice cold air to turn in some real fast times (assuming you can hook it up).
Bob Saveland
Former owner of #2517
Old 11-07-2009   #2
Aurora40
Aurora40's Avatar
Default Re: Final drag racing of the season
I'm on the fence about going on the 22nd now. Traction was terrible today. Every run, shift to second, blow the tires away big time... Even backing off a little and rolling back in, they'd go. It sucked. Traction out of the hole wasn't bad, so it may have been track prep plus the temps, I dunno.
Bob Saveland
Old 11-08-2009   #3
Bob,
I went today and it was a super weather day at Byron, IL. Temps got up to 72F. Tried some of the Ranger tips. Changing the clutch fluid really made a difference in the shifting. However, trying to hold the rpm at the line was difficult. My best 60' was a 2.1. Best run was a 12.9 @ 117.26
I ran a DA correction for both this run and the runs I did at Great Lakes in September.
Today's run was corrected to 12.6@119.8. The GLD run was 13.0@118.6
corrected to 12.7@120. So pretty consistent. I need DRs badly. Found that best psi was 29.5 hot.
Old 11-08-2009   #4
Aurora40
Aurora40's Avatar
I was running about 32psi hot in the rears. I cut two 2.1 sec 0-60's in spite of never having what felt like a good launch. So that part was sticky, or reasonable at any rate.
Temps were in the high 50's, and my best run was a 13.1 @ 113, which included the requisite letting off of the gas in 2nd gear and pedaling it until 3rd.
Bob Saveland
Old 11-08-2009   #5
QB93Z
QB93Z's Avatar
Bob, Great to hear that you are out there running your Z. I would like to join you, but I am busy every weekend this month.
I got to make a couple passes in the Yellow '94 down in Texas so I did get to do some drag racing this Fall.
1990 Black ZR-1 - sold
1993 Quasar Blue ZR-1
1994 Competition Yellow ZR-1
1995 Dark Purple ZR-1
Maryland State Coordinator
Old 11-08-2009   #6
Yeah that 2nd gear tire spin has to count
for something. Gotta think it's worth couple of tenths and 1-2 mph top end.
Old 11-09-2009   #7
Scrrem
Scrrem's Avatar
Love to join you on the 22nd, but I may not have my back together by they. If I get the axle back in, I'll try to make it.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
