Go Back   ZR-1 Net Registry Forums > Club Regional Areas > East Central Region
Old 11-04-2009   #1
Default Last Chance Drag Race
Here's the weather for Saturday
High: 61 °F RealFeel®: 59 °F
Partly sunny
Anybody up for Byron? Probably last shot this year.
Old 11-05-2009   #2
Bob G
Default Re: Last Chance Drag Race
Sorry My pistons are in South Carolina
Bob G is offline   Reply With Quote
Old 11-05-2009   #3
Bob,
Geez! When you blow a motor up, you REALLY BLOW IT UP!
Old 11-06-2009   #4
Bob G
There back, will be assembling it on sunday
Old 11-07-2009   #5
I went today and it was a super weather day at Byron, IL. Temps got up to 72F. Very easy to hot lap today with hardly anyone there. Tried some of the Ranger tips. Changing the clutch fluid really made a difference in the shifting. However, trying to hold the rpm at the line was difficult. My best 60' was a 2.1. Best run was a 12.9 @ 117.26
I ran a DA correction for both this run and the runs I did at Great Lakes in September.
Today's run was corrected to 12.6@119.8. The GLD run was 13.0@118.6
corrected to 12.7@120. So pretty consistent. I need DRs badly. Found that best psi was 29.5 hot.
Old 11-14-2009   #6
I need DRs badly.
Yeah, that seems to be a long time issue with your car - getting the power on the ground. I remember hearing the rpm runaway at US41 a year ago, even in second gear. Your trap speeds say you have the power to do better, but it ain't getting to the ground, or so it seems to me as well.
For comparison, my (stock) 90 ran 13.1 at 111mph the day you were running 12.8 and 12.7 ish at around 118. (Anyone smell rubber burning?)
P.
Old 11-14-2009   #7
Paul,
That's why at this point I use the track to tune for hp using trap speed.
Real world dyno with ALL the factors thrown in.
Old 11-20-2009   #8
There's a LOT to be said for that. Back in the day, a stretch of blacktop and a stop watch and 4th gear was what we used. Problem was the limited number of data points (just one - was a handful for someone doing it themselves). Course, we were limited as to what could be done too: Lessee... #34 jets or #36s? Course, weather conditions on any given day frustrated results as much as differences between dyno calibrations do now.
P.
Old 11-20-2009   #9
Yeah and things like lighter weights or springs,
more or less timing, hotter or colder plugs, change the dwell angle.
Old 11-21-2009   #10
I fussed a little with that stuff too - musta had a pound of weights n springs at one time, single and dual points kits, etc, etc. Gave it up for lent when a local shop would "curve" it to whatever ya wanted.
Speaking of which, there is a solid state "drop-in" replacement for the points - meaning the end of having to constantly be chasing timing/dwell. Gonna give it a try (Ami's Vette). It runs about $75, I'm told - put on to it by a local speed shop mechanic friend of mine.
On another note...Bout time for some more pizza, yes?
P.
