Old 11-01-2009   #1
Default McMaster Carr cap screw part #s?
Couple items: (I did a search, and was not able to find the specific part #s.)
  1. Can anyone verify the McMaster-Carr part number (or provide the specs) for the 6 small cap screws used on the cam cover for me? I have #91292a138
  2. Also, what is the part number (or specs) for the plenum screws?
Thanks in advance.
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 11-01-2009   #2
tccrab
tccrab's Avatar
Default Re: McMaster Carr cap screw part #s?
Here's what I saved from that original post many moons ago.
I have not bought them for myself (yet)
TomC
"Crabs"
93786A150 (washers) - 10 per pack : 5 packs
91292A156 – 10 per pack: 5 packs
91292A144 – 25 per pack : 1 pack
91292A148 – 25 per pack : 1 pack
91292A147 – 50 per pack : 1 pack
91292A138 – 50 per pack : 1 pack
95 bucks
QTY 24 Metric 18-8 SS Socket Head Cap Screw M8 Thread, 55mm Length, 1.25mm Pitch, Packs of 10 (min quantity 5) 91292A156
QTY 8 Metric 18-8 SS Socket Head Cap Screw M6 Thread, 50mm Length, 1mm Pitch, Packs of 25 (min quantity 1) 91292A144
QTY 12 Metric 18-8 SS Socket Head Cap Screw M8 Thread, 25mm Length, 1.25mm Pitch, Packs of 25 (min quantity 1) 91292A148
QTY 6 Metric 18-8 SS Socket Head Cap Screw M6 Thread, 25mm Length, 1mm Pitch, Packs of 50 (min quantity 1) 91292A138
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 11-01-2009   #3
I have 6 of the small ones if you want them. I had to buy 50 from McMaster (min qty)
these are for the front of the cover
Old 11-01-2009   #4
Certainly!
P.
90 #1202
Sans secondaries
Old 11-01-2009   #5
TomC
"Crabs"
95 bucks
Thanks!! I copied this and put it in my ZR-1 file.
P.
90 #1202
Sans secondaries
Old 11-01-2009   #6
Certainly!
P.
When do you need them?
Old 11-02-2009   #7
With any good luck (had some of the other recently), maybe in a couple weeks?
I work is based in Addison, so you're not a big jump from there.
P.
90 #1202
Sans secondaries
Old 11-02-2009   #8
Paul,
What's the latest on the cylinder head repair?
Old 11-02-2009   #9
Paul,
Barring any more leaks and its on to have the valve job done, seals installed, and some of Pete and Bob's magic and look out! With any luck, maybe another 500 hp FBI Z will be born!?
Definately got the itch to hear that baby growl again!
P.
90 #1202
Sans secondaries
